How do you drive you 5AT Manumatic?
Old May 27, 2007 | 09:53 PM
  #61
mmassad's Avatar
Yeah mine is always in 4th right when I switch over, I wish there was some way around this...
And definitely keep your foot on the gas all the way into 5th, it is designed for that.
Old Jun 4, 2007 | 11:52 PM
  #62
oooooooooooooq's Avatar
bump
Old Jun 4, 2007 | 11:54 PM
  #63
Wannabe6MT's Avatar
-MN G Crew-
My friends 2006 Toyota Avalon Limited is always in 4th to, but if im at a stop or somthing and flick over its in 1st, but when im moving it puts me in the gear it was in.
Does anybody elses car do this?
Old Jun 5, 2007 | 09:45 PM
  #64
-= SKiZO =-'s Avatar
Mine matches whatever gear the car is in when in the auto mode.
So if I flick over it to manual, it may say 7 or even 8th gear depending on the speed.
Old Jun 6, 2007 | 12:42 AM
  #65
MAKK's Avatar
how does the manumatic exactly work, ive been searching on pic's and or detail's but can't seem to understand.
Old Jun 7, 2007 | 08:11 AM
  #66
Castro's Avatar
Correct me if I'm wrong but I believe it just limits the maximum gear you're allowing the transmission to shift to, and it's computer controlled. It can down shift on its own (you have it in fourth and come to a stop, it will downshift rather than stall out) but it won't upshift unless you tell it to.
Old Jun 7, 2007 | 08:22 AM
  #67
w0ady's Avatar
fgc moderator
ok ill share since you guys are so funny. i used it rarely until about a year ago when i installed my injen cai and ses. i just couldnt get away from the sound of redline after that. i sold the exhaust but i still love to play with it most of the time.
Originally Posted by JHPIV
WOT, at 6k, tap up to the next higher gear, and again...and again...well, you get the idea. :-)
+1. because of the delay, when im getting on it i shift at 6k because it shifts around 6500-6700 which is the peak of our powerband.
Originally Posted by Chrlesmd
From personal experience, make sure you're actually in manual mode before trying to upshift
ive pulled this smooth move lol.
Originally Posted by GLuXuRy
just keep bouncing it off the rev limiter in first
JP
Just keep your foot planted to the floor .. when the tach reads 6k .. upshift ... and when you get the timing down .. you can go a lil past 6k and upshift and you wont hit the rev limiter
+1.
Originally Posted by jackygor
brake torque on launch...rev to about 2-3k and punch on the gas
You would only want to do that on the tracks of course!
To fully utilize the MM, make sure you shift to gear 1 in parking lots so you can hear your exhausts...
did this on the way home last night. its even more fun when its wet! (on the track of course) lol
Originally Posted by digital1986
When I shift over into manumatic it already has me in 4th gear its weird........also when I do shift it takes about 1.5 seconds to acutally shift it suck!
90% of the time, D uses 4th gear. it all depends on your speed. if you try it at slower speeds, you'll see 2nd and 3rd mostly. just a side note, 5th gear kicks in at 120mph.
Old Jun 7, 2007 | 08:41 AM
  #68
G35x-06's Avatar
When your cruising at around 50 and above, and you have it in D it is in 5th gear. The reason when you slap it over to manumatic and it drops to fourth because it is for dropping one gear and passing.
Old Jun 7, 2007 | 11:23 AM
  #69
plutonium239's Avatar
Originally Posted by oooooooooooooq
How do you drive you 5AT Manumatic? how do you do it, when do you shift, tips, just share everything you know!!
.....I don't. I've never been happy with how it works. Sometimes when I use it, the transmission won't shift, requiring me to select the gear again. !st to second shift is really sluggish and slow, like a slipping clutch then 2nd to 3rd shifts fast and rough. A good idea, a poor execution.
Old Jun 10, 2007 | 01:48 AM
  #70
Nickypoo's Avatar
Yeah I have issues with mine missing gears also, just let the trany do it!
Old Jun 11, 2007 | 04:37 PM
  #71
whiterhino529's Avatar
hahhaahhahaa ive done thatDOMO
ive also one time forgot that i was in the shift mode and was red lining cause the radio was to damn loud
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
Frostbite91
Aug 12, 2015 05:16 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
socalg35x
Jul 28, 2015 10:42 AM
