Outdoor temperature sensor
Old Aug 8, 2007 | 10:48 AM
Dan in St Louis's Avatar
2004 G35x, my outdoor temperature sensor reads 12 - 15 degrees F below the actual temperature. Before I pull it and check its resistance against the calibration chart, has anyone else had this problem?
Thank you!
Old Aug 8, 2007 | 10:51 AM
RBull's Avatar
Rated M
I had mine replaced about 2 months ago but only because it seemed to be very slow to adapt to changes.
Just get the dealer to replace it under warranty.
Old Aug 8, 2007 | 02:51 PM
gwhiz35's Avatar
There was a tech bulletin for the sensor, but the reason for the replacement is that they usually read much higher than the actual outside temp after the car is operated, then parked, then operated again.
Agree w/RBull, talk to your service rep to see if you can get it fixed under warranty.
Old Aug 8, 2007 | 03:02 PM
I found a disturbing statement in the service manual. It says that in order to avoid constant fluctuation the response was intentionally slowed to no faster than 0.6° F change every 100 seconds. That would be 0.36° F per minute, or 3.6° F in ten minutes.
In other words, if you are moving from a cool garage onto the road, or have stopped to buy something and the engine has heat-soaked the sensor, it could be a half hour before it reads the truth! Avoiding meaningless noise in the readings is great, but a half hour? Duh.
I also heard about a reset procedure posted a couple of years ago, and it seems to help:
https://g35driver.com/forums/showpos...52&postcount=9
Old Aug 8, 2007 | 04:31 PM
saborz's Avatar
I have tried the reset procedure, and it definitely works.
As of late, mine hasn't been getting stuck at the lower temp, but a couple of months ago, it was getting stuck all the time.
see:
https://g35driver.com/forums/showthr...73#post2100073
Old Aug 8, 2007 | 07:02 PM
ttrank's Avatar
Grocery getter
Mine reads high after sitting in the sun all day but I have seen it go down in temp way faster than what you read. Typically within 5-10 mins of driving it has come down to the outside temp.
Old Aug 8, 2007 | 08:14 PM
That's good, maybe the manual has a misprint. Nah, no way!
Old Aug 9, 2007 | 07:06 AM
cato's Avatar
SouthernComfort Moderator
Same here.
Old Aug 9, 2007 | 03:11 PM
ttrank's Avatar
Grocery getter
Mine read 109 when I left work last night and 10 minutes later it was at 101 which is about right.
Old Sep 4, 2008 | 12:47 AM
zhadow04's Avatar
where is the sensor located?
Old Sep 4, 2008 | 02:35 AM
psedog's Avatar
Back in SD**
Mine has been reading high (10-20deg) ever since I picked it up in Japan. Something in shipping really fkd it up.
I've seen 123 on my dash and I wasn't dying when I went outside. It was hot, but definately not that hot. I'm going to try that reset procedure.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
mattdg35
Sep 14, 2015 11:28 AM
