How to measure the engine Oil level
Old Mar 24, 2018 | 09:52 AM
  #31
FreshLikeAG's Avatar
With oil filter change: 5 qts
Without oil filter change: 4 5/8 qts
Dry engine(overhaul) 5.75 qts
Old Mar 24, 2018 | 09:53 AM
  #32
LoSt180's Avatar
Originally Posted by G2B35AGN
Note the two carets at the end of his comment. That points to second post above. One caret would point to your post.
But I did learn what a caret is tonight so thanks fellas for the education. I had no idea that one indicated the post immediately above and 2 referred 2 posts above.
Tell me about it. Now I feel like an idiot for putting a random number of carets all ***** nilly. Normally just quote the post, maybe it's the new norm since you can't quote on social media platforms.
Old Mar 24, 2018 | 12:00 PM
  #33
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah I always use 3 carets ^^^ I guess I've been doing it wrong this whole time.
Old Mar 24, 2018 | 12:04 PM
  #34
G2B35AGN's Avatar
How exciting. I've started a thing.
Of course it sort of breaks down if you want to point to a post 12 prior.
Old Mar 24, 2018 | 01:49 PM
  #35
Scorpi0's Avatar
All this talk about carets is gettin me hungry.
Old Mar 24, 2018 | 02:10 PM
  #36
Hall Stevenson's Avatar
I think that's the '03-'04 dipstick, traditionally oil.level is ALWAYS filled to the top of the hashmark, the more volume in the crankcase the better, never fill to the middle of the hashmark.
That image is from the FSM for the '08 G35. The dipstick in my '08 has the "H" and "L" markings as well (see attachments). I've always read that you want the oil level right in the middle of whatever markings are used on the dipstick, be it "H" and "L", hashmarks, notches, etc, etc and anywhere in that 'range' is fine. If your car takes ~5 quarts but you didn't let it drain fully, that 5 quarts might push you towards the 'high' side but can be okay, for instance. You definitely don't want to overfill which can it to create bubbles (air).
Also, the oil on my dipstick flowed towards the "H" while I got my phone (camera). When I removed it, it was almost a 1/4" below the "H".
My apologies: I didn't realize this was in the '03-06 sub-forum. I've been reading, reading, reading and learning as much as I can and didn't pay attention.
Attached Thumbnails How to measure the engine Oil level-img_1304.jpg   How to measure the engine Oil level-img_1303.jpg
Old Mar 24, 2018 | 02:12 PM
  #37
I've been on forums or the like for almost 20 years (starting with slashdot.org, then DSL Reports, and so on) and have never heard of using "^" to refer to 1 post up, 2 posts up, etc !
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
ghost_g35
Aug 7, 2015 10:31 AM
ClwMike
Jul 23, 2015 12:55 PM
