Stupid intake questions....
is it better to get a JWT Z-Tube/pop-charger combo or a STILLEN HI FLOW INTAKE W/Z-TUBE KIT
or a carbon fiber z-tube [http://www.g35parts.com/9083/osc/pro...roducts_id=306w/ either air-box from stillen or pop-charger from JWT?
which will give more power and which will give more sounds?? or both.???
intake will give you at most 3hp. It's mostly for the sound and looks.
If you want looks, get the CF z tube. I should have got one because then I could have gone with a CF z tube, CF engine cover, CF battery covers...
I would go with the Stillen because the cone is cover and doesn't take in heat from the engine bay like the JWT. I would just get a K&N air filter and z-tube. The stock air box is pretty well designed and keeps heat out.
