Does your G ever overheat?
ok, now i am thinking it could be the cap
I jacked the car up, took the plastic cover off, and sat under the car while i turned it on and waited for coolant.
I could see no cracks, loose hoses, or anything, anywhere.
After about 5 mins, when the fans kicked in over drive, i finally saw it. It was comming from the very bottom of the radiator, between where the metal and plastic meets. It started flowing, i jumped up and looked at the car temp gauge, and it was about 3/4 of the way.
Is this the symptoms of the faulty rad cap?
Its almost as if there is to much pressure in the system, and once the heat gets up there, its leaking from the seems, during normal temps no leaking at all.
Seems like the rad cap, if not venting properly could cause heat and build up of pressure. Man i hope its just the rad cap.
jon!
jon!
Possibly a faulty radiator all together...i got a new one when i brought my car in for the same reason except i had no leak....i used to work for infiniti and we used to replace radiators all the time....they're crap...it should be covered under warranty once they see the problem. Dont let them just give you a radiator cap, make them give you a new radiator and cap and coolant...start fresh
thanks so much man, i hope im still covered, i just got this car 3 weeks ago
Im gonna pick up a radiator cap from autozone tommorow, if that doesnt fix it im gonna take it in.
I think the warranty was 4 years, 60k miles for 2004, but im not positive.
Ill take it in monday
Whatever you do..do not put that aftermarket radiator cap on that car...if you do that they will instantly void out your warranty and blame it on the aftermarket cap....trust me..they will try to find anything to keep them from having to do warranty work. Just take it in as it is..if you do not want to drive it..call infiniti roadside assistance..that's what i did and they towed me for free because the car was under warranty.
Like other said, check the radiator cap. Mine had some orange gunk inside of it. It caused the top radiator hose (coolant return) to decompress and collapse. After I cleaned it up, it is fine since.
i cleaned the radiator cap didnt help, coolant is def leaking very bad.
Im taking it in, tom morning first thing
I hope my car is under warranty, its 4 years 60k miles for 2004 right?
The warranty is transferable to new owner right?
Hope they give me a loaner
jon!
jon!
UPDATE:
They are replacing the radiator under warranty, should be ready today.
Overall great experience! They didnt give me a loaner car(said you need to book one a week in advance??), but they did give me a ride home (luckily i have a 2nd car i can use)
jon!
jon!
Glad they are fixing it...seems to be the same problem i had
Dropped it off monday morning, picked it up tuesday afternoon all covered under warranty.
They didnt have any loaner cars to give me, but they did drive me home, to get myother car, and did the same when i picked it up.
Really great service, i was very impressed.
My car is back to normal now and i love it!
nettcar
Aug 25, 2024 11:59 PM
It is why I took mine in for service just before it expired and had my seat fixed.
