Compression rod sound is back..
Old Oct 4, 2008 | 01:43 PM
  #61
Tollboothwilley's Avatar
they have an upgraded/newly redesigned bushing.
Old Oct 4, 2008 | 02:07 PM
  #62
you can pick up the bushings for around $40...but you will need to find someone with a hydraulic press that can push out the old ones and push in the new.
call around if you dont know anyone...
Old Oct 7, 2008 | 08:57 AM
  #63
nas4a's Avatar
Anybody know how long this TSB is covered under warranty? I have a 2003 model purchased in Dec. 2002, with about 78,000 miles, so I'm guessing I'm not covered, but wanted to check.
Old Oct 7, 2008 | 09:21 AM
  #64
GF-4D-G35's Avatar
A TSB does not extend the warranty. You are unfortunately out of warranty.
Old Mar 24, 2010 | 11:38 PM
  #65
batanatoly's Avatar
I have same problem (05 G35 Coupe) please anyone. I want to know how you replaced the compression rod. I will be changing them soon.
Do I need to remove the cross arm underneath the compression rod (where the rod is mounted), how do I take it out.
Pictures will be very helpful.
Thank You
Old Dec 7, 2010 | 06:19 PM
  #66
HIAG35SILVER's Avatar
It is #9 not # 8
Old Dec 7, 2010 | 06:37 PM
  #67
Wannabe6MT's Avatar
-MN G Crew-
Is this covered under power train warranty?
  #68
007JD's Avatar
i had the same problems with the squeaking noise
they told me it was my control arms bushing
they put it on the left and showed me
the wearing down of the bushing
they are trying to charge me 150$ for just the labor
they havent told me the price of the part
they told me to go with a after market cause there harder and wouldnt squeak
so im not sure what to do yet
cause i think the labor price is a bit steap
Old Dec 7, 2010 | 07:40 PM
  #69
Blue Dream's Avatar
I drove ttrank's car solo
Some dealers will and some won't from what I've seen.
Old Jan 27, 2011 | 12:21 AM
  #70
brentcd's Avatar
Yeah, help please. I was just told my compression rod bushings are cracked. 2006 G35x. Any special tools or talents or is this a fairly straightforward job. What/Where exactly is the Comp Rod Bushing? Is it basically the ball joint?
Old Jan 27, 2011 | 01:20 AM
  #71
not the ball joint - its the other side with a rubber bushing. They go bad. Just buy some new ones and have them pressed in.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
dcsbh1
Oct 1, 2015 03:15 PM
