Swapping Sedan/Coupe seats in 03 - wiring info
Old Jan 9, 2018 | 11:27 AM
  #61
JCLA03G35's Avatar
Originally Posted by deuce3333
Well i got my coupe seats in today and they do have memory option. My sedan seats don't have the memory so the plugs r different the coupe has 12 wires and sedan as 4. So i hooked up the wires as said above and the seat doesn't work. when i press the forward button i hear it make a clicking noise. Does any one know if u have to bypass the memory option in order for the seat to work? I see people talk about bypassing a control module
Deuce3333,
I'm in the same boat right now. I installed the driver's side seat the way that was suggested in this thread, but all i'm hearing is clicking noises.
Did you ever figure out how to fix this?
Old Jan 23, 2023 | 03:26 AM
  #62
Chance413's Avatar
G35 coupe
Is the wiring interchangeable?
I just got an 03 g35 coupe and I need to change the drivers seat but all I can come across are seats for a G35 coupe 04 and up. And I know that if it's an 04 and up the seat has an additional button that may not work which I'm okay with. My question is if I get a seat from an 04 or up, would plugging it in be the same, or would I have to mess with the wiring to get the seat warmer and everything working?
Old Jan 28, 2023 | 11:21 AM
  #63
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You'll definitely be messing with the wiring.
Old Dec 11, 2025 | 09:05 PM
  #64
G35sedan23's Avatar
2006 G35 Sedan seats into 2006 g35 Coupe
Hey guys i know y'all started this thread when I was 1 year old but hopefully someone can help me. Im trying to swap 06 coupe seats into my 06 sedan. I can’t find any wiring diagram for these two plugs. The coupe seat i’m trying to put in has a 6 pin plug, I need help.
Old Dec 11, 2025 | 09:24 PM
  #65
srv2nv's Avatar
G35 Sport
Did you download the FSM? It should have the pin layout in there.
Old Dec 11, 2025 | 09:26 PM
  #66
G35sedan23's Avatar
Nope I will look at it thank you
Old Dec 12, 2025 | 11:48 AM
  #67
05_SkylineSedan's Avatar
20 Year Member
Your subject line says sedan seats into a coupe but your message says coupe seats into a sedan. In either case, here are the manuals. Scroll down beloe the "viewing window" and you can "Click here to download a copy."
https://www.nicoclub.com/service-man...F2006%2Fse.pdf
Old Dec 12, 2025 | 05:24 PM
  #68
ray1370's Avatar
Is this for driver seat? And does your sedan come with memory seat function? As far as I know the main harness connector should be 12 pin, where do those two connect to your sedan seat originally?
RedOtter
Nov 12, 2017 02:18 PM
w1zzzy
Oct 17, 2012 06:59 AM
b-dRizZy
Interior
Jan 5, 2011 12:35 PM
Vic101
Jan 22, 2009 12:00 AM
SW22GT3076
Interior
Jan 28, 2008 09:40 AM
