Compression Rod Replacement
Old Dec 20, 2008 | 03:25 PM
maxpusher's Avatar
20 Year Member
Hello,
I went to the dealer a couple of weeks ago to get the squeek noise in the front checked out. They found that the compression rod bushings were cracked and replaced just the bushings under warranty. The car was drove for a couple of weeks and now the noise is starting to come back. I don't know if it is the cold weather here (32 F) or if the bushings are starting to go bad again.
I found a lot of people were having issues with the compression rod bushings. Question: When the dealer worked on your cars, did they change just the bushings or the whole compression rod? Is there any change to the new compression rod design? This is for an '05 G35 with sports suspension. Just wanted to know what your results were. Thanks.
Old Dec 20, 2008 | 03:28 PM
bythabay's Avatar
Originally Posted by maxpusher
Hello,
In my case the entire rods were replaced. If the problem comes back though, I'll just be swapping out the bushings.
Old Dec 20, 2008 | 03:29 PM
PAIXAO's Avatar
My dealership replaced both rods also.
Old Dec 20, 2008 | 06:00 PM
maciejk's Avatar
spray them with some silicone lube, the creak will go away like mine did
Old Dec 20, 2008 | 07:40 PM
gtbigup01's Avatar
Does this sound that you guys are talking about sound like struts squeaking? I've had this for a while but thought it was because it was cold. What happens if it doesn't get fixed? I have 2 months left on my 4 yr warranty, and about 13,000 miles
Old Dec 20, 2008 | 07:56 PM
TwinInfin's Avatar
The first time they lubed the bushings. When I complained a week later they looked at it and said they ordered parts to fix it. That was a week ago so they should be calling anytime to schedule it up.....
Old Dec 23, 2008 | 10:59 AM
samudj01's Avatar
Anyone know the TSB# off the top of their head. My front end sounds terrible and my warranty runs out in Feb. I plan to get this fixed in Jan. and I want to be armed with the info to get them to take care of it the first time as opposed to having to go back multiple times. Thanks.
Old Dec 23, 2008 | 02:18 PM
TwinInfin's Avatar
Not of the top of my head but go to infinitihelp.com and create a membership. You will be able to look up all TSB's for any Infiniti.
Old Dec 23, 2008 | 06:33 PM
gtbigup01's Avatar
I dropped my car off yesterday for comp rod squeaks and the replaced just the bushings. picked my car up today. I had one day of a 08 loaner, pretty fast.
MyfistYourFace
Aug 8, 2015 11:58 AM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
LoSt180
Jul 15, 2015 08:31 AM
