Need Help! belts
Old Jan 5, 2009 | 01:19 AM
entranzdG's Avatar
Need Help! belts
So i was driving on the freeway today on my way home and as i turn off the off ramp my steering starts to feel heavy as if the power steering went out my house isnt that far off the freeway so i risk it and go home, when i get home i open my hood to find that the front belt is broken im not the most car tech savy person but after searching i found that we dont have timing belts but timing chains so what was broken most likely wasnt the timing chain, now my question is what belt is this and is it a easy fix? i want to make sure i know what the problem is before i go into get it fixed so i dont get ripped off, also is this belt related to power steering? as my power steering went off as this broke thanks in advanced!
Old Jan 5, 2009 | 01:39 AM
jack_burton's Avatar
dood you are one lucky guy...that belt runs a couple other vital components i think
Old Jan 5, 2009 | 01:42 AM
g whip's Avatar
there are two belts in the car one skinny one and one fat one. if u can tell me what one broke i can help u out.
Old Jan 5, 2009 | 01:45 AM
Hotdawwgman's Avatar
Damn, you have a clutch fan... I bet your car is loud when you first start it eh?
Sorry about your problems, kinda curious to which belt broke.........
Old Jan 5, 2009 | 01:46 AM
AARONHL's Avatar
Replace both of them from AutoZone or equivalent, very easy to do. Search for A/C belt changing...
Old Jan 5, 2009 | 01:47 AM
entranzdG's Avatar
the belt in the last picture is the one that broke is it hard to tell which belt it is from that picture? how do i tell the difference in the too
Old Jan 5, 2009 | 01:48 AM
entranzdG's Avatar
are these belts related to power steering?
Edit nevermind one belt if for ac and the other is for power steering
Old Jan 5, 2009 | 01:52 AM
AceG35X's Avatar
I just recently replaced both belts.. my suggestion if one broke.. its only gonna be a few months till the other breaks if that.. I got both belts off Struas Auto and it cost me $25.. i installed them myself and only took 30 mins.. loosen 2 bolts.. take off the old belts, put the new ones on, and tighten up the bolts.. as far as other components it might affect i have no clue.. but i strongly suggest getting them both replaced..
Old Jan 5, 2009 | 01:54 AM
entranzdG's Avatar
ok ill get them both replaced is there a diy anywhere?
Old Jan 5, 2009 | 01:56 AM
AceG35X's Avatar
I would do a search.. if you can't find any its really simple.. just loosen on of the bolts till u feel the belt get loose.. and same for the other belt.. *might need to loosen two bolts...
entranzdG's Avatar
ok i found it for anyone else interested heres the link
thanks for the quick responses guys!
oh btw i think both of my belts broke lol im lucky im made it home with no problems so far.. hopefully everything goes good tommorow after i install new belts
https://g35driver.com/forums/engine-...lt-change.html
Old Jan 5, 2009 | 01:58 AM
AceG35X's Avatar
haha i was just about to post that link.. yea man thats more in depth but its a real simple change.. good luck
Old Jan 5, 2009 | 02:17 AM
entranzdG's Avatar
thanks for all the help man really appreciate it
Old Jan 5, 2009 | 11:52 AM
G35Papa's Avatar
STICKY
https://g35driver.com/forums/g35-sed...eo-series.html
Look for "Drive Belts Replacement"
Old Jan 5, 2009 | 12:07 PM
pinkii's Avatar
Dang... good thing I am dropping my car off at the dealer today for a battery test (to see why my ish keeps draining batteries) and also to get the belts looked at. I started it the other day and until it warms up it is squeaking really bad.
