Sedans are as fast as coupes. go and tune
Old May 13, 2009 | 02:56 AM
  #166
silG35's Avatar
i have an 06 auto sedan and it said premium recommended. so is it only the sedan sport package is premium required?
Old May 13, 2009 | 11:26 AM
  #167
pwebb's Avatar
any VQ will take 91 or better. the options package does not matter. engine stays the same.
Old May 13, 2009 | 11:30 AM
  #168
350Zed's Avatar
Not true.
For '05-06...
5AT (sedan and coupe) = 282 hp and 269 lb·ft of torque, 91+ octane recommended
6MT (sedan and coupe) = 298 hp and 258 lb·ft of torque, 91+ octane required
Old May 13, 2009 | 11:55 AM
  #169
RPL's Avatar
RPL
^Why would the transmission make any difference to what gas is required/recommended?
Old May 13, 2009 | 12:00 PM
  #170
350Zed's Avatar
The engine was tuned differently depending on which tranny it was mated to.
Question it all you want, but I'm stating fact straight from Infiniti here.
Old May 13, 2009 | 04:27 PM
  #171
silG35's Avatar
my friend's 06 5at coupe is premium required. That's what im confused about.
Old May 13, 2009 | 04:32 PM
  #172
350Zed's Avatar
Tell him to RTFM, and he should find it says "recommended" not "required."
Old May 13, 2009 | 04:36 PM
  #173
RPL's Avatar
RPL
I'm not doubting that it may be listed like that. What I'm questioning is if it makes any sense. Each engine is going to have the same compression...
Old May 13, 2009 | 04:39 PM
  #174
350Zed's Avatar
...but may have different timing and/or different AF mapping in the ECU.
Old May 13, 2009 | 09:07 PM
  #175
DaveB's Avatar
It has more to do with the extended redline of the Revup engines.
Old May 13, 2009 | 10:38 PM
  #176
350Zed's Avatar
How would you explain the lower peak torque on the 6MT variant then?
Old May 13, 2009 | 11:28 PM
  #177
KJT's Avatar
KJT
Rtfm 2005
Copied and pasted directly from the 2005 manual (pdf) -- *no* distinction between AT and 6MT:
FUEL RECOMMENDATION:
Sedan models
Use unleaded regular gasoline with an octane rating of at least 87 AKI (Anti-Knock Index) number (Research octane number 91).
For improved vehicle performance, INFINITI recommends the use of unleaded premium gasoline with an octane rating of at least 91 AKI number (Research octane number 96).
Coupe models
Use unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (Research octane number 96).
Old May 14, 2009 | 10:38 AM
  #178
350Zed's Avatar
Sedan models
Coupe models
Copied from the 2006 manual (pdf):
FUEL RECOMMENDATION
Sedan - Automatic transmission models
Sedan - Manual transmission and Coupe models
Old May 14, 2009 | 02:16 PM
  #179
RPL's Avatar
RPL
None of this makes any sense to me. Am I the only one?
Old May 15, 2009 | 11:37 AM
  #180
Klubbheads's Avatar
marketing bullsh!t. Any year coupe or sedan including G37s will not blow their engine on 87 octane. They will be slow as **** but nothing will happen.
