G35 Sedan Suspension Picture Compilation Thread
Old Sep 28, 2012 | 02:47 AM
  #1261
INFINITI06!'s Avatar
Originally Posted by SS06Sedan
with the coupe springs you may be fine, depending on what size tires u decide to go with specially for the rears, so most users here go with 225/ 235/ even 245/35/19
im running 225/45/18
dont forget about getting a camber kit if you go lower than 2 inches, or ur gonna run thru tires very fast.
and if you got AWD makes it a bit harder since you cant really mess with staggered wheels...
Sweet im running 245/35 already so ill be good but u said i would need a camber kit with he tein springs?
Old Sep 28, 2012 | 04:29 AM
  #1262
frontieragent's Avatar
05 on BC coils
BC BR Coilovers
Attached Thumbnails G35 Sedan Suspension Picture Compilation Thread-image.jpg
Old Sep 28, 2012 | 07:21 AM
  #1263
RicoG35x's Avatar
I'm running 225/45/18
don't forget about getting a camber kit if you go lower than 2 inches, or ur gonna run thru tires very fast.
Actually you CAN run a staggered wheel setup like the coupes do on an AWD.. it's not so much the WIDTH of the wheel/tire combo.. it's the overall CIRCUMFERENCE of the wheel/tire combo.. more so the DIFFERENCE between the front and rear wheel heights.
For example if you're running 225/45/19 in the front that has an overall height (vertical profile) of 26.1", which rotates at approx. 796 revs per mile, then you run 245/35/19's on the rear which has a vertical profile (height) of 25.8" and rotates at 805 revs per mile, the DIFFERENCE in rotational speed between the front and rear wheels is what will mess with the AWD system, depending on what differential the system is programmed to trigger on, it will fire the "SLIP" light and try to compensate for what it interprets wheel spin road conditions and who knows WHAT state the system will go into if this condition continues.. may error out and put the car into that funky state where the throttle by wire system will never let you go above 20 or 30 mph... had that trigger on mine due to a bad brake sensor one time!?
So anyways.. that's what will kill you with staggered setups.. if there is too much difference between the front and rear height/circumference... yes, the AWD system will have an aneurysm.. all by design at that. The key is to get this to a minimum as possible.. plus it will mess with your speedo reading.. the SMALLER the tire from OEM.. the SLOWER your car is actually going, regardless of the speedo reading.. the BIGGER.. the FASTER you're going.
in this example, with the 225/45 (26.1"@796 revs per mile) in the front, fitting a 255/35 in the rear (26.0"@799 revs per mile) would get you within .8 MPH and well within any SLIP sensor issues with the AWD system on the G... that and it would have an AWESOME look to the car with THAT setup!!! HA!!
(time for fender flares at that width!! )
Old Sep 28, 2012 | 07:50 AM
  #1264
MPG35fiend's Avatar
DPE ARiSTOs
G35X
19x9.5 +22 225/40
19x10.5+17 255/35
currently ride height is 25 1/4 inches from floor to fender, but cambering the front will lower it a but more.
these pics the front is 25 1/16... way too low. under tray scraped at low speeds.
Old Sep 28, 2012 | 07:55 AM
  #1265
RicoG35x's Avatar
bad a$$ for sure dude!!
Old Sep 28, 2012 | 08:08 AM
  #1266
MPG35fiend's Avatar
thanks man.... its been a rough road.... lol. almost done with my build i think?? need more polished parts for engine bay, bbk, air ride suspension then moving on to interior. hahaha i think im almost done??
Old Sep 28, 2012 | 08:49 AM
  #1267
RicoG35x's Avatar
HA!.. it's NEVER done.... modding is like CRACK ON WHEELS!!
have FUN bro!!
Old Sep 28, 2012 | 08:58 AM
  #1268
MPG35fiend's Avatar
Lol I know man....
Old Sep 28, 2012 | 10:27 AM
  #1269
SS06Sedan's Avatar
Nice! thanks @RickoG for actually breaking down the science, lol
most people wont get camber kits i did just for the simple fact the guy selling his S Tech was selling the SPC Camber kit as well and i got everything for $200
but other than that, some like the tucked in/ slanted wheel look. if its a daily driver, tires will be destroyed very fast!!!
Old Oct 1, 2012 | 12:46 AM
  #1270
colinhuemmer's Avatar
NIce rides!
Old Oct 3, 2012 | 02:03 PM
  #1271
chris32086's Avatar
any springs fit g35 sedan x??????
Old Oct 3, 2012 | 02:20 PM
  #1272
MPG35fiend's Avatar
Yes. Do your research on google and this forum will pop up. Or simply type in G35x on search bar and many threads are made regarding this question. Good luck!
Old Oct 8, 2012 | 09:05 PM
  #1273
BrianUzi's Avatar
2004 G35x Sedan
Lowered on Tein H-Tech Springs, 19" Parallax Verde Wheels
I'm going to paint the wheels soon because I don't like the current look,
What does everyone think about matte silver? I'm trying to go for a budget Vossen cv3 look.
Old Oct 9, 2012 | 02:36 AM
  #1274
bootchoy's Avatar
coupe struts with megans
Old Oct 9, 2012 | 10:51 AM
  #1275
Texasscout's Avatar
Love the black wheels and headlight housings. Though about a black grill too?
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
