G35 Sedan Suspension Picture Compilation Thread
Rating: Thread Rating: 4 votes, 4.75 average.
Old Dec 17, 2012 | 07:49 PM
  #1336
bootchoy's Avatar
Originally Posted by SDGenius
your front sidewall to higher than your rear
yeah, i went with the 2007 (i think) oem setup
Old Dec 17, 2012 | 07:54 PM
  #1337
SDGenius's Avatar
no OEM setup has a taller front, the only 50 profiles I've ever seen on our cars were for 17's
Old Dec 17, 2012 | 08:04 PM
  #1338
bootchoy's Avatar
it is on g37 and saw a few g35 on here running same setup.
Old Dec 19, 2012 | 12:41 AM
  #1339
SkinnyD35X's Avatar
I've looked on here for a while now, but I haven't seen anyone with the setup, but anyone using Eibach Sportlines on G35x?
Old Dec 19, 2012 | 10:40 AM
  #1340
JaE35's Avatar
Moderator
G35 Sedan
that's more than likely too low up front for an X which is why you haven't seen it
Old Dec 19, 2012 | 12:13 PM
  #1341
LisettesGSedan's Avatar
Great thread with lots of good information...thanks
Old Dec 19, 2012 | 05:10 PM
  #1342
SkinnyD35X's Avatar
Ok thanks. Got a free set from a z. Thought I would research it before I tried.
Old Dec 19, 2012 | 05:37 PM
  #1343
JaE35's Avatar
Moderator
G35 Sedan
it's a very very low drop...probably lowest springs made for our cars
Old Dec 28, 2012 | 11:06 AM
  #1344
Chucks 04's Avatar
Originally Posted by az1anbeethoven
2006 revised 350z springs + shocks
WORK T1S
20x8.5 +38mm front
20x9.5 +45mm rear
New suspension set-up is: 350z s-techs with tokicos coming in 1-2 weeks! Will post pictures soon!
First off let me say that your G looks great love the color combo they you did. So what I want to know is where did you find the grill and do they come in the OEM color?
Old Jan 4, 2013 | 11:06 AM
  #1345
Ednica87's Avatar
Originally Posted by lexusk8
Here's my '03.5 sitting on Eibach Pro-Kit springs (1.1" drop all around) and HP Evo's 19's:
IMAGE#1
since you've drop the car an 1" have you noticed any wear and tear trays unusual? suspension problems?
Posted from G35driver.com App for Android
Old Jan 4, 2013 | 04:06 PM
  #1346
Ednica87's Avatar
I'm looking to get some springs and curious to why so many people get 350z or g coupe springs/strut shocks etc. what's the advantages then looking up straight sedan kits?? ups/downs?? I would assume it would be more complicated trying to find front and rear instead of just getting a kit made specifically for the sedan?
Old Jan 4, 2013 | 04:07 PM
  #1347
Ednica87's Avatar
p.s. I'm not trying to be rude or an *** just very curious.
Old Jan 4, 2013 | 04:47 PM
  #1348
RicoG35x's Avatar
mostly has to do with the ride height and ride comfort (spring rate).. whether it's too bouncy in the back with passengers in the back of the sedan and a good, even balance between front and rear wheel gap so you're not pointing uphill or downhill... at a standstill!
Old Jan 4, 2013 | 04:59 PM
  #1349
dominate's Avatar
Much of the aftermarket drop springs have spring rates that do not correlate to stock: meaning that aftermarket springs on stock sedan shocks will wear out the shocks faster. This is why I decided to go with a full 350z suspension, 1 inch drop all around, and everything matches up, no premature wear.
Old Jan 7, 2013 | 11:27 AM
  #1350
Cummins24v's Avatar
Looking to drop on sport lines on stock sport suspension and 18's, anyone have rubbing or scrape issues, I live in upstate NY lot of potholes and bumps. Don't want to hurt the car, thinking might b a little low but they look so good
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
