Driver door rubber strip
Old Jun 19, 2009 | 05:11 PM
thescreensavers's Avatar
Mr.202?
well I ripped mine and now a portion of the top part is not there, the little part that overlaps uptop, is this a DIY able? Can I get this piece solo or do I need to go to a dealer.
thanks
Old Jun 20, 2009 | 08:09 PM
Mr.202?
Bump
Any one?
Old Jun 21, 2009 | 12:24 PM
Tranquil's Avatar
I was trying to find one of the seals for the door, the weather strip that attaches to the body, but couldn't find it on the part break down over at Riverside.
I'd suggest just asking your local friendly Infiniti dealer and they'll know the part number. That's who you'll have to buy from anyway.
...and that last sentence was foreshadowing of my own
Old Jun 21, 2009 | 01:08 PM
OCG35's Avatar
deleted previous - I look a thte pic wrong...
Old Jun 21, 2009 | 03:10 PM
Mr.202?
Yea I think I am going to go to my local infiniti dealer.
Does anyone know how to install this part. The labor rate here is like 130.
Old Jun 22, 2009 | 10:45 AM
G35 Mass's Avatar
Update? I need to replace mine. All four are dry-rotted.
Old Jun 22, 2009 | 03:03 PM
ttrank's Avatar
Grocery getter
+2 I would like to replace mine too. I assume they can be purchased from the dealer.
Old Jun 22, 2009 | 03:54 PM
Mr.202?
I assume this also, but I don't know how easy it is to install. I hope someone can post up how. I am going to call the dealer now to find out how much.
Old Jun 22, 2009 | 06:56 PM
pwebb's Avatar
they're easy to do. a few clips, a few strips of double sided tape.
much easier once you have the new strips in hand. easier to see what you're dealing with.
clean up the old tape residue thoroughly. dont pull the backing off the new adhesive until you are clipped into place.
to get the strip into the top groove, stand on the inner side of the door and work the inside edge in first. I might be thinking of the v36, but I'm pretty sure the v35 has the same set up.
cheers
Old Jun 22, 2009 | 07:13 PM
Mr.202?
cheers
The tape comes on the strip already? How do you remove it just pull up on a random section and keep pulling and all of it will pop out?
Thanks
Old Jun 23, 2009 | 02:09 PM
Mr.202?
I just called again and finally got someone, they want 158 bucks for the part with out installation. I smell bull. Fuuu
Old Jun 24, 2009 | 04:35 PM
Mr.202?
Ok so I found out a site that sells these parts and I can get it for 90 shipped
http://www.infinitipartsusa.com/part...layCatalogid=0
I am pretty sure #5 is the right part.
Also If someone could explain the installation and uninstall procedure?
Thanks
EnCr1pt3d
Jul 8, 2019 02:48 PM
mike730
Jan 12, 2018 04:25 PM
apintojr
Jul 23, 2015 10:52 AM
