trunk release
Old Jul 20, 2004 | 07:24 PM
seinsmeld's Avatar
trunk release
I have a few electrical problems on my G35 sedan. The trunk release sometimes doesn't work when I press the interior release or on the key fob. If I put the key back in and turn the ignition both will work. Of course when I go to the dealer they can't duplicate same. Let me know if any of you guys have experienced this problem. Your help would be appreciated.
Old Jul 22, 2004 | 10:25 PM
bosssho's Avatar
Re: trunk release
The key fobs are not the best period...doors, trunk...the only thing that always works great is the damn panic button. lol
If the trunk release on your dash does not work than you have a legitimate problem.
John
03.5 G35 5AT 14.2 @ 96
7 Wire Grounding Kit
K&N CAI w/Injen Heat Shield
UR UD Crank Pulley
NISMO Mid Pipe
Crawford V 5.0
TS
02 Maxima SE 4AT 14.5 @ 95 (Wife's)
87 Mustang GT 13.2 @ 107
Old Jul 22, 2004 | 11:25 PM
ABQ_G35's Avatar
Re: trunk release
I have not had one problem with my keyfob, I actually like that you have to hold the trunk release down for it to open, my last car the damn trunk release was way too sensitive, I'd come out sometimes and the damned trunk would be popped, geez! Not with the G!
Brilliant Silver/Graphite/Chrome Wheels '04 Sedan/5AT
Old Jul 22, 2004 | 11:40 PM
tgenius's Avatar
Re: trunk release
When I put my aftermarket alarm, I actually had the installer disconnect the line to the trunk from inside the trunk, that way, people can't get to my sub/amp/changer. The only thing that opens my trunk right now is the Viper 2way remote, which I find to be a damn good replacement for the OEM FOB.
2004 G35s 5AT DG/Graphite/Premium/Huper Optik Tint
Old Jul 23, 2004 | 12:43 AM
jstwong's Avatar
Re: trunk release
I too have encountered this problem once before. I'm not too sure what caused it, but neither the key fob nor the interior release would open my trunk. I too just put the key in and turned it to the on position, then back off. That seemed to reset the situation and then everything worked just fine. Never have come across this issue again [so far at least].
Old Jul 23, 2004 | 12:51 AM
shodog's Avatar
Re: trunk release
double check the disable switch in the glove box and make sure it is on. If it's turned off then obviously the the trunk release isn't going to work.
Jim
'03.5 Sedan
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Jul 23, 2004 | 08:05 AM
bosssho's Avatar
Re: trunk release
I thought of that Shodog, but after reading that they could open it after a while or by resetting things by turning the car off and on, I figured it couldn't be that easy.
I just don't feel the range is anything to write home about with these key fobs...my 0ld 2000 Maxima and my wife's 2002 was and is a lot better.
John
UR UD Crank Pulley
NISMO Mid Pipe
Crawford V 5.0
TS
Old Jul 24, 2004 | 02:52 PM
jstwong's Avatar
Re: trunk release
I too did the double check on the glove box switch. When I ran into my problem, my first thought was, "How did I accidently hit that switch?". None the less, it has only happened once, so I have no idea what the problem is / was...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
