z suspension
Old Jul 27, 2009 | 08:53 PM
0710ralford's Avatar
z suspension
I know that there is a search function and I have used it but can't find much on what exactly I would like to know. I am new to putting mods on cars so with that being said if there is a thread about this someone please point me in the right direction.
I would like to lower my 05 G sedan about an inch all around. I have 20" wheels around so I am not really sure if it will work on my car cause I got 8.5 with a 40 offset without contacting my fender. But anyways I saw a thread about revised z springs and something about regular z springs....
1. What is the difference, and I am under the impression this will lower about an inch all around. Correct??
2. Is there any other options out there that will lower an inch or is that the best/cheapest option??
Again I really don't know much about the car scene and if there is a thread answering exactly what I am asking point me in the right direction.
Thanks,
Brad
Old Jul 27, 2009 | 10:01 PM
Blue Dream's Avatar
I drove ttrank's car solo
A few of us are rocking the Tein H Techs. A little over 1" drop in the front and a little less than 1" drop in the rear. New cost less than $200.
Old Jul 27, 2009 | 10:54 PM
itgogitrev's Avatar
Blue Dream, do you know what the H-Tech spring rates are?
Also, what shocks/struts you using?
Old Jul 28, 2009 | 07:35 AM
Blue Dream's Avatar
The H Techs are 324 F and 263 R compared to 342/314 stock on the sport suspension. I have the stock sport suspension.
Old Jul 28, 2009 | 07:59 AM
NjMatteSedan's Avatar
I heard good things about the skunk 2 springs also, they lower about the same as the H techs but they're 60 bucks cheaper, you don't really need to upgrade the shocks with a mild drop like that, but with the Z springs you do
Old Jul 28, 2009 | 10:11 AM
How much could I expect to pay to get springs installed?
Old Jul 28, 2009 | 10:40 AM
Depends on where you go, could range from 150 to 300. I think most shops charge around 200
Old Jul 28, 2009 | 11:43 AM
canucklehead's Avatar
doing it yourself is relatively easy, especially with a friend and a spring compressor. 3-4 hrs and a case of beer is all is cost me. don't forget to do an alignment after ~2 weeks.
Old Jul 28, 2009 | 05:20 PM
Unleaded's Avatar
If you can find a complete front 350z shock and spring already assembled with the top mount, you do not need a spring compressor. It's just a direct swap.
Old Jul 28, 2009 | 11:18 PM
Sursa's Avatar
I've got 07 350z springs and shocks with 19 inch m45 rims. Still a lot of room to go lower but a lot better than stock
Old Jul 29, 2009 | 02:56 AM
350GT-R's Avatar
would coupe spring work for awd sedan? tell me please!!
Old Jul 31, 2009 | 04:45 PM
So I am under the assumption that you can just get a set of z springs and put them on without having to swith out other suspension as well as getting vehicle cambered. Is this correct? I have 20's and just want to get rid of most of the gap.
Thanks in advance.
Old Aug 2, 2009 | 09:28 PM
Tollboothwilley's Avatar
yes, you should be fine to do just the springs.
You should find a set of revised springs. 2004.5+
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
