License plate thing missing?
Old Sep 9, 2009 | 04:24 PM
iTzTeddy's Avatar
I was about to buy LED for my license plate to replace the light, and I realize...I don't have the housing? I'm guessing when I bought it, it was removed? or that comes separate. All I see when i look up that hole where the rear license plate is a big gap and 2 metal rectangles pieces on the left and the right side...i doubt that is the light. Anybody else have the same problem
Old Sep 9, 2009 | 05:02 PM
olopez's Avatar
Sounds like you are missing these. They come stock.
http://www.trademotion.com/partlocat...layCatalogid=0
Old Sep 9, 2009 | 05:25 PM
G SEDAN's Avatar
pwned
Old Sep 9, 2009 | 10:01 PM
iTzTeddy's Avatar
yes those are exactly what im missing. your the man lopez.
Old Sep 9, 2009 | 10:49 PM
iTzTeddy's Avatar
Is it possible for the lamp to someone pop out of place and fall behind into the gap. Because I got rear ended once thats why im wondering, and i do see a black thick wire in there, ill try pulling it back up and see.
Old Sep 9, 2009 | 11:07 PM
G SEDAN's Avatar
if you got rearended and had it repaired....the shop might've never replaced it or just didnt install it back properly so its possible it can just be behind, or it can just be the wire and nothing attached to it.
Old Sep 10, 2009 | 10:49 PM
iTzTeddy's Avatar
Ok. What I actually found out today when I reached into where the lamp is suppose to be is a long black thick wire. I grabbed it and try to pull the lamp out hoping there was one. What I found was the line was just connected to another place I don't know what. So that means I will need to buy the lamp, but the price ain't bad. Thanks A lot guys.
Old Sep 14, 2009 | 09:14 AM
geew1z's Avatar
before you buy it... you may want to make sure that whatever that wire is attached to isnt the lights and they are just stuck between the actual bumper and bumper cover..
Those lights plug into a connector under the left taillight, which you can see if you take off that taillight..
boostelevator
Sep 29, 2015 03:23 PM
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
crazy_g35s
Jul 20, 2015 02:30 PM
