Moving Gear Lever?
Old Aug 24, 2004 | 02:47 PM
doogie's Avatar
Moving Gear Lever?
For those with 6MT, I have to know: When you gas on and off in, say, 3rd gear, does your shift lever move slightly? Mine does it all the time and I'm trying to decide whether I need to get it looked at in case I have broken or loose engine / tranny mounts or if this is just par for the course in this car. It seems to move forward and backward vs side-to-side, which, given the setup of the engine and tranny, seems backwards to me. I'm worried I have bad mounts like I had in a previous car. If that's the case, getting the dealership to change them under warranty is going to be tough unless they're completely fuxx0rd.
Anyone?
Jase aka Doogie
04 G35S
Old Aug 24, 2004 | 04:50 PM
3point5SE_Auto's Avatar
Re: Moving Gear Lever?
yes it does move, slightly (less than 1/2 inch). This is normal in the MT cars I have driven before.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Aug 25, 2004 | 02:28 PM
doogie's Avatar
I've only ever owned manual transmission cars and other than when they have engine mount issues I've not witnessed it as much as this car has. What's the setup of this shifter with regards to it's relationship with the selector shaft on the transmission? Is it a cable system, or rods? what is it? does anyone have some sort of diagram?
Jase aka Doogie
04 G35S
Old Aug 27, 2004 | 01:35 PM
andyranck's Avatar
It's not a cable, hence the vibration in the **** all the time. Mine moves like you describe, so I'd think it's normal. You can't exactly yank it out of gear very easily with the clutch engaged, w/out giving it a little gas, so I wouldn't worry about it accidentally getting out of gear on you.
Drew
2003 G35 Sedan 6MT / Black / Graphite / Prem / Aero
Old Aug 27, 2004 | 07:27 PM
kailep's Avatar
Mine does the same thing....
It's funny my other 2 cars (mine & wife's car), Civic and VW Cabrio don't do that..
But I've driven others recent years stick shift cars and they do move like you describe.
2004 G35s 6mt, Tb/willow, prem pkg, Nismo body kit
Old Aug 28, 2004 | 01:23 AM
this cars gear shift is coupled directly to the transmission thru the gear box. in a fwd car it is connected to the tranny by a cable or linkage or sometimes electronically. there is enough slack in the cable and linkage to reduce the vibration more than in this car
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
