Re-oiling K&N cone filter...
Old Feb 12, 2010 | 02:29 PM
mikeee2's Avatar
Originally Posted by jimmykce1
Mike;
go to this post and read all about replacement dry filters: Stillen CAI dry filter replacement.
It looks like there is an Amsoil cone filter, which is longer than the Stillen and the AEM dry filter.
which post???
Old Feb 12, 2010 | 03:08 PM
Epidel's Avatar
I just cleaned mine last night using the k&n cleaning kit, used the cleaning spray 1st then put it in a bucket of water with some oxi-clean then used the cleaning spray again just to make sure it was really clean (Also let it sit for a bit between cleaning methods) Let it dry over night. In the morning sprayed the oil on it let it sit for 30 min then installed it, hopefully that was a good enough amout of time for it to settle in either way it will be sitting in the parking lot at for work a while
Old Feb 12, 2010 | 05:17 PM
BuckeyeInMI's Avatar
Originally Posted by G SEDAN
2 cleanings?
damn i've done like 4 and still have about half way to go
I think he was referring to a cone filter vs. your flat filter. I re-oiled my flat one and have plenty left for several more uses.
Old Feb 12, 2010 | 07:18 PM
OCG35's Avatar
have I been doing it wrong?...
you mean you dont just dunk the air filter in the drained motor oil during oil change?...
Hmmm - I better check my MAF sensor
Old Feb 12, 2010 | 10:22 PM
Epidel's Avatar
i was once told spam non stick spray would work also so that way if a egg some how worked its way in there it would not stick to it
Old Feb 13, 2010 | 12:35 AM
GAU-8's Avatar
Holy crapola! Lulz!
Old Feb 13, 2010 | 06:16 PM
OCG35's Avatar
chitya! great idea
this way the dirt particles will slide right off and not clog the free flowing air! So Brilliant!
I'm gonna go by a case of Pam!
cmesidewayz
Sep 29, 2015 09:28 PM
kytran40
Aug 4, 2004 06:21 AM
neffster
Intake & Exhaust
May 18, 2004 09:20 AM
