Everybody that switched to Mobile 1 synthetic
Old Sep 8, 2004 | 04:27 PM
illphilly215's Avatar
How many here are burning oil/having problems from switching to Mobile 1 synthetic?
03.5s/Brillant Silver/Premium/Sport/Winter Pkg
Old Sep 8, 2004 | 04:51 PM
karlhungus's Avatar
Re: Everybody that switched to Mobile 1 synthetic
Not me. Been running M1 5W/30 since 2200 miles, and have 42000 on it now. Uses about a qt. every 3500 miles.
Old Sep 8, 2004 | 05:35 PM
G35Five_O's Avatar
I've used it my last two oil changes and no problems.. Knock on wood..
My vehicle takes a beating from everyday driving.
Old Sep 8, 2004 | 05:55 PM
karlhungus- Do you always fill up at 3500 miles? I noticed oil was burned when I changed the oil @3100mi. I think it was at least 1/2 qt.!! Is this normal??
I don't like how our cars drink up synthetic! I always thought with synthetic you could change your oil at 4 - 5k intervals! How many miles do you guys change your oil??
For my sister's Mazda 3, the "Factory recommends" changing oil @ 5k intervals with dino oil...which is weird.
Old Sep 8, 2004 | 08:03 PM
number6's Avatar
Switched to Mobil 1 5W30 at the first 3500 change. No consumption at all - now at 8K miles.
The Prisoner
------ We want information ...
2004 G35 Sedan AT w/ Premium, Leather, Wood, Sport & Michelin Pilot Sport A/S @ 235/50ZR17 on Stock Rims
Old Sep 8, 2004 | 08:29 PM
SixFive's Avatar
22k 5w30 and i've added maybe 1 quart ever
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Sep 8, 2004 | 08:55 PM
CookG35's Avatar
I've used Mobil1 since 2K miles, now have 33K miles. I change every 5K and NEVER needed to add oil. In fact, the level indicated on the dipstick does not change at all, much as I can tell.
Old Sep 9, 2004 | 10:55 AM
3point5SE_Auto's Avatar
Mobil 1 5w-30 from 7000 miles to 33k miles, Mobil1 10w-30 since (now at 41k miles), no oil used or burnt and the engine sees redline daily. also have 40k miles on a previous VQ35DE engine with no oil usage running Mobil 1 5w-30 and 10w-30.
for all of you who think you may be burning oil, do you fill it to the line after an oil change? if so, that is too high. the line is "hot" level. following an oil change or other times when the oil is cold, the level should be at the 1/2-3/4 mark. then when you turn the car on and heat it up the level will expand to the full mark
this is why nissan recommends checking the oil hot at 10 minutes following shutdown. this ensures the oil is still hot but all the oil has drained back to the sump.
if you fill it too high the oil will foam and get carried over with the air to the PCV system to your intake tube and into your throttle body. This is not necessarily bad if it is only 1/4-1/2 quart high, just wasteful and inhibits efficient combustion.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Sep 9, 2004 | 11:08 AM
cato's Avatar
SouthernComfort Moderator
I have been using Mobil 1 5W-30 for a year or so and have
never had to add oil.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Sep 9, 2004 | 12:08 PM
G35_TX's Avatar
Switched to Amsoil at 1000 miles. No problems here at 16 of miles currently duing 6k oil changes. No loss of oil.
2004 Infiniti G35S, 6MT, Premium, Sport, DP
Mods: JDM Clears, 20% tint, Z-tube, Stilen CAI
Track: 14.32 at 98.79 mph 2.2032 60ft
Dyno 07-07-04 - 234.2 hp & 233.8 tq
http://www.g35world.com
Old Sep 9, 2004 | 01:14 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I don't mean to Hi-jack the thread, but.....
Those that are not losing oil; How did you break your car in?
I broke mine in hard (not abusive) & use no oil at all.
IJMO but I think this seats the rings better.
<font color=blue>04 Silverstone G35, 5AT, Prem, Aero
ES100 225/45-18 front 245/40-18 rear
HKS & Y-pipe, Z-tube, Eibach, 35%Tints</font color=blue>
Old Sep 9, 2004 | 03:10 PM
I did 700 miles the first day following the break in procedure. after that I "drove it like I stole it". I had a 8000+ rpm misshift (5th to 2nd instead of 4th) at about 1500 miles. I changed my oil immediately after that, then again at 3750.
Old Sep 9, 2004 | 04:34 PM
G35_TX's Avatar
My car was broken in hard. Mine had 300-400 miles on it when I got it. All from test drives. So I am sure it wasn't treated nicely. And I was easy on it till 1000 miles, then I started getting on it really hard, but I did run it at the track with 800 miles. So like I said, it had a hard break in.
Old Sep 10, 2004 | 03:44 PM
SoCalTed's Avatar
been running M1 since my first oc at 3k. I change my oil every 3k using M1... I am at 12k, no problems.
gonna do an analysis on the next change cuz i have the UR pulley now.
-T
'03.5 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS - www.teamtransport.org
Old Sep 10, 2004 | 04:24 PM
Q45tech's Avatar
Mobil 1 [all the various iterations] since 1991 [90Q] currently 268,000 miles changed every ~~4,000 miles.....never more than the rare 5,000 interval...............my records show 67 oil/filter changes.
402 quarts and never added anything between changes.
Overkill surely but whats $2,000 worth of oil [a $1200 increment over the $2 a quart stuff] [compared to $23,000 in gasoline] in 14 years.
Still doesn't burn a quart between changes!
But the ring cylinder wall design of the 90 Q was quite robust.
Dallsinghjr1
Sep 17, 2023 11:25 AM
MrIP35
Oct 25, 2015 11:13 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
