Please help noise is driving me up the wall!
Old Mar 6, 2010 | 01:44 PM
BXBORO's Avatar
Angry Please help noise is driving me up the wall!
My 03 sedan recently started makin a very loud "spinning" type. Noise. It sounds like something is rubbing against the wheel. As i accelerate the noise gets extremely loud. The steering wheel also tends to shake but as i go faster the shaking gets more serious. I checked to see if anything was rubbing and i could not locate the problem. Its sooo anooyin and eextremely loud. Does any1 here have an idea of what this could be?
Old Mar 6, 2010 | 03:10 PM
GreenPenguin's Avatar
Hmmm. Did you check all your lug nuts to see if any are loose? Or any warping on the rotors? Does it seem to come from any particular wheel well?
Old Mar 6, 2010 | 07:53 PM
socalwdup's Avatar
Did you drop yo car huhnay??
Old Mar 6, 2010 | 07:56 PM
deeznutts23's Avatar
does it make a noise when you hit the brakes?
Old Mar 6, 2010 | 08:09 PM
TwilightSedan's Avatar
I have a similar noise, i think it may be the bearings but i don't know which wheel.
Old Mar 6, 2010 | 08:19 PM
worn out bearings make a roaring noise fyi
Old Mar 6, 2010 | 09:11 PM
BXBORO's Avatar
thank you guys so much i really appreciate this. im gnna look into all the options postedabove.
Old Mar 6, 2010 | 09:13 PM
BXBORO's Avatar
i did not drop the car. and the noise comes when i accelerate. i did however take the wheel off a couple of days ago. the passenger side and thats where the noise is coming from. its amazing how u guys can diagnose problems right here on the spot by a brief description.
Old Mar 6, 2010 | 09:50 PM
Yea, whenever you remove a wheel you wanna make sure u torque all the lugnuts down as tight as possible when reinstalling. push the wheel up against the rotor and use one of the nuts to hold it in place. Start the nuts by hand so there's no cross-threading. If done correctly the wheel should be perfectly flush on it's mount. Let us know if this is the fix for your problem mate.
Old Mar 6, 2010 | 10:32 PM
Tollboothwilley's Avatar
could be a wheel bearing going out. They start out as a whirring sound.
Also, could be a brake caliper sticking...in which case the easiest way to know is to feel the middle of the wheel on the center cap. It will be much hotter than the rest of the wheels if your caliper is sticking.
Old Mar 6, 2010 | 10:43 PM
Now that's some quality information I needed too. My pads look good but i'm getting squeeking noise like they need replacing. I'm also getting this whirling noise from the rear of the car as i accelerate. I'm going to try to measure the heat, should I brake more to create a better read?
Old Mar 6, 2010 | 11:24 PM
socalwdup's Avatar
There was a recall on that axle grinding when you drove from PARK.
TSB it
rezendvous420
May 31, 2020 01:26 PM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
