Tire question
Old 05-08-2010 | 12:21 PM
Mustang5L5's Avatar
It's a small difference but not ideal.
Stock diameter with 215/55 is 26.3, while youth new 225-50 are 25.9" in diameter.
Either way, I would put the correct size tires on. You either want 215/55 or 235/50. If you are using this car year round in snow and only use 1set of wheels, go with the 215/55.
Did you not sake for a specific tire size before you went In for tires? Or did they put something different on?
With wad, you should replace all four at once anyway. On some gm models, the all wheel drive system will go into error if you change only two because it senses the difference between new tires and worn old tires. The g35 system has some slip built in, but do not hit the snow button with two different tire sizes or you can cause some damage then
Old 05-08-2010 | 11:45 PM
BuckeyeInMI's Avatar
You don't have to run 215/55 or 235/50, you just have to run the same diameter front and rear and be close to the stock diameter of 26.3". Here are the sizes you can run on a 17x7:
215/55-17 (26.3" - stock)
225/50-17 (25.9" - 1.7% smaller than stock)
225/55-17 (26.7" - 1.7% larger than stock)
235/50-17 (26.3" - stock +0 sizing)
They're all close enough to 26.3" so you won't have problems with the VDC, and as long as they're all the same diameter, your AWD won't be affected. Notice I said same diameter. You can run a 215/55-17 up front and do a simulated stagger with a 235/50-17 in the rear without any problems other than you can't rotate them and have to watch your tire wear a little closer. I run 225/55-17's in the winter and don't have any problems
Old 05-10-2010 | 01:24 AM
oscar_g-sedan06's Avatar
Originally Posted by BuckeyeInMI
Holy chowder, those fronts are WAY too small. Stock front is 225/45-18. You're about 6.75% smaller than that with those 35's. I don't think it's possible to look aggressive with such a small tire. I'd get those changed out ASAP.
The only way to cover gap is to drop the car. You could run grossly oversized tires, but there are too many other problems with that.
oops i meant 225/45 front and rear 245/45
911Turbo
19 Inch
08-24-2016 08:31 AM
Kng0fHrts
09-15-2015 05:40 PM
G35Sask
Intake & Exhaust
16
08-05-2015 10:17 PM
mushu
07-15-2015 03:55 PM
Quick Reply: Tire question
