drive belt question
Old Jun 16, 2010 | 05:40 PM
socialconflicts's Avatar
drive belt question
so took my car for an oil change, they recommended drive belt on the inspection notes. they said it was cracked. do they mean the compressor belt? this is what i got from the search in everythingg35.com
Old Jun 16, 2010 | 08:37 PM
Blue Dream's Avatar
I drove ttrank's car solo
You have 2 belts on the front of the engine. I would recommend replacing them both if you need to do one. I got both OEM belts for $36 and it literally took about 25 minutes to change them out myself.
Old Jun 16, 2010 | 11:40 PM
would i need something to loosen the tension? like when replacing the alternator the belt is under tension... something similar?
i got 666 posts...
Old Jun 17, 2010 | 06:27 AM
Blue Dream's Avatar
There are 2 tension bolis on each side of the car. I think they are 12mm but can't remember exactly. Just loosen the bolts on the pulleys first and you're good to go.
Old Jun 17, 2010 | 09:39 AM
GreenPenguin's Avatar
Yes, the tensioner bolts are 12mm. The pulley bolts are 14mm/ 916, and the under carriage shield bolts are 10mm. My pulley bolts had siezed up quite a bit and I stripped them while try to get em off so be careful. If you strip em like I did then run to sears and pick yourself up a breaker bar and a bolt-out set( got my set for ten bucks). If you don't have a tension gauge then before you remove the belts just use you finger to get a rough feel of the tension in them. Worked for me!
Old Jun 21, 2010 | 08:08 PM
barrios35's Avatar
Why do you have to loosen the pulley bolts? Shouldn't the tensioner bolts do the trick? Never replaced them on the G yet but every other car you just move the tensioner with big wrench and the belts comes loose.
Where did you buy the belts? Need to do this soon.
Old Jun 21, 2010 | 08:26 PM
From my understanding, the tensioner bolts won't move on the G unless the pulley bolts are first loosened. I got my belts from Nissan for $67. The belts are the same for the 350z.
Old Jun 21, 2010 | 09:28 PM
ray1370's Avatar
Just follow the DIY in tech area, it has clear step by step instructions with pics. I printed it out and got mine done in less an hour at night with poor lighting. Riverside Infiniti gave me a good deal on the OEM belts, you can call them and order from them.
Old Jun 21, 2010 | 10:37 PM
DaveB's Avatar
Cracks in the belt doesn't mean replacement is needed. When the ribs actually start breaking off is when it's time to replace. These belts can last a long time.
Old Jun 22, 2010 | 12:52 AM
mine are cracked from the inside. i just dont wanna risk them braking on my trip ima be taking so i will get it done now just for my own sake and peace of mind.
Old Jun 22, 2010 | 10:17 AM
barrios35's Avatar
Anyone ever ordered from them?
http://cgi.ebay.com/ebaymotors/OEM-I...Q5fAccessories
Wayne9011
Aug 17, 2015 01:24 AM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Wayne9011
Jul 27, 2015 11:25 AM
EasySausage
Jul 14, 2015 11:17 PM
