Anyone had this problem on their G35x
Old Jul 7, 2010 | 08:57 PM
kevintandmd's Avatar
Hi,
I have a 2004 G35x with 19 inch coupe wheels with 245/40/19 tires. Today, I started my car and drove a few blocks than all of a sudden, the tire pressure warning light goes on. I checked the tire pressure at the gas station and everything seemed fine, no pressure loss.
I drove the car again and a few minutes later, the tire pressure warning light goes on. I kept on driving for a few minutes and then the VDC light, Slip light and AWD light goes on. I couldn,`t use the turn signals, my AC didn`t work as well as the tachometer. I could drive a little bit but when I accelerate, I could feel the rear wheels nudge, like it had posi-traction...
I turned the engine off and waited a few minutes before starting the car again. It did the same thing after a few minutes of driving.
Does anyone know what the problem is? Could the tire pressure sensor cause multiple problems that I have just described?
Any suggestions will definitely help
Thank you very much.
Old Jul 7, 2010 | 10:03 PM
G35xTurbo's Avatar
I've never heard of anything like that. Are you sure all 4 tires are the same size? It sounds like the AWD system is being confused which makes me think the tires are different sizes...
Old Jul 7, 2010 | 10:33 PM
All four wheels are 19 by 8.5 with 33mm offset and with the same 245/40/19 tires. The tire pressure warning light goes off first and after a few minute, the other lights goes on. Does anyone think changing the tire pressure sensors will cure the problem?
Old Jul 7, 2010 | 10:45 PM
Matzo Ball's Avatar
Sounds like an eletrical issue. TPMS cannot be the culprit.
Old Jul 7, 2010 | 11:00 PM
SLVRG35X's Avatar
is the overall all diameter of your new wheels bigger than stock. if so that might be the problem.
Old Jul 8, 2010 | 12:34 AM
G35xChicago's Avatar
^ it shouldnt be, hes got the right sizing. Sounds like he isnt even running them staggered??
Sliip/VDC/AWD almost always come on together, and it can be caused by a whole slew of issues. Mine, for example, was a ruptured wheel speed sensor. Do some searches around the forum to see what other members have experienced in that same sequence.
Old Jul 8, 2010 | 02:30 AM
350GT-R's Avatar
the wheel has a virus. u need a scan immediately. lol
Old Jul 8, 2010 | 09:53 AM
Dan in St Louis's Avatar
VDC light
Slip light
AWD light
AC didn`t work
Primary power failure -- battery, alternator, battery cables...
Old Jul 8, 2010 | 10:12 AM
PAIXAO's Avatar
^ +1
Old Jul 8, 2010 | 10:51 AM
I made an appointment with the Nissan dealer so hopefully they can figure what it is.
Jiggerjuice
Oct 5, 2015 02:33 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
atk08
Jul 30, 2015 03:12 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
EasySausage
Jul 14, 2015 11:17 PM
