Why the price difference? (Compression Rods)
Old Jul 9, 2010 | 08:38 PM
5150DS's Avatar
They are going for around $350 a pair on ebay for factory part. Over $500 for labor is ridiculous. Find a local mechanic or diy. You could always get a pair of new rods and keep the old and have new bushings pressed in so you always have a spare. = little down time.
Old Jul 9, 2010 | 08:41 PM
Jairen's Avatar
Is there a DIY? It seems simple enough to change out.
Old Jul 9, 2010 | 11:35 PM
Kfizzle's Avatar
I just did this yesterday since my bushings were torn. I had nothing but a cheap set of tools also. It took maybe an hour and a half. This is a really easy job IF the nut to get the ball joint off doesn't spin with the bolt(mine didn't). Its basicly like this:
1. jack up car remove wheels
2. remove pin to get off ball joint nut
3. use 19mm(12 sided socket preferably) socket to remove ball joint nut
4. use 19mm socket(probably need breaker bar) to remove the nut where the bad bushing is
5. use 10mm socket to remove the bolt holding the plastic cover thingy near the bad bushing lol
6. use 14mm socket to remove the V shaped frame piece
7. use a hammer to knock out old rod/bushing(surprisingly easy for mine)
8. install new rod and torque as needed
I wrote this in about two seconds but from what i recall that was about it, sorry if the socket sizes are off since i'm not 100% sure on what exactly they were but this is close and not hard to figure out once your under the car.
I also had on hand new ball joint seats since i heard getting old ones off the ball joint can be tough, that probably helped with time some. I ordered my compression rods, bolt stoppers and ball joint seats from Riverside. I think it all ends up around $450 and install was an easy diy for me.
These new rods are the best thing I have done to this car. My ride was noisy and the steering just didn't feel right. Now the car feels like new.
Hope this helps
Old Jul 10, 2010 | 12:21 AM
G35xChicago's Avatar
Originally Posted by Jeff92se
We REALLY need aftermarket ball joints from someone like MOOG to be available!
Moog FTW, i sell their high precision servo valves!
Old Jul 10, 2010 | 12:42 PM
TurTLe*'s Avatar
Originally Posted by Jairen
looks like we have no serviceable ball joints... so to replace the ball joints you really have to replace that whole arm... $300 arm at that...
Old Jan 27, 2011 | 01:34 AM
brentcd's Avatar
How much does this all change for X - AWD cars? In another post it's a whole different rod?
Also, are the ball joints replaceable, should the whole rod be replaced to renew the ball joint before it goes bad?
Old Jan 27, 2011 | 03:18 PM
drkay's Avatar
i just replaced both compression rods because the ball joint on one was bad, i tried to do it myself but it was seized on and it had to be torched off. i got both revised AWD rods for 300 CDN on ebay!
Old Jan 27, 2011 | 06:12 PM
Wannabe6MT's Avatar
-MN G Crew-
I still havn't replaced my compression rods... lol
Old Jan 28, 2011 | 11:19 AM
VincenzG35's Avatar
haha i need to do this soon that or shocks/springs i just want the creeks out when i drive
Old Jan 28, 2011 | 11:38 AM
teahead's Avatar
If ball joints bad, yes replace whole thing.
If just the bushings, take 'em out, and have any frame/alignment shop press out/in the old/new bushings.
http://cgi.ebay.com/ebaymotors/OEM-I...item3a5c336888
Old Jan 28, 2011 | 01:56 PM
liljohnny's Avatar
For $20 more.........
http://cgi.ebay.com/ebaymotors/OEM-I...item3a5c1051db
Old Jan 28, 2011 | 03:15 PM
teahead's Avatar
Used rods? No thanks.
It looks like you CAN replace the ball joints if they go bad???
http://cgi.ebay.com/ebaymotors/2-FRO...item3f06befa0a
Or are these for maybe the lower control arm and not the compression rod???
MyfistYourFace
Aug 8, 2015 11:58 AM
kinetek
Aug 3, 2015 04:25 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
itschuckster
Jul 25, 2015 08:07 AM
LoSt180
Jul 15, 2015 08:31 AM
