Random Little Question Thread
Old Nov 3, 2010 | 05:59 PM
  #1591
Wannabe6MT's Avatar
-MN G Crew-
Question, how can you tell the TPMS are out of wheels? I think mine were switched when I didn't know about it, but the TPMS light only came on with my 19s when i was on the freeway but now it stays on permanetly with my 17s on and all the tires are up to air spec. How hard is it to install them back onto the 17s and where can i find them/what do they look like?
Old Nov 3, 2010 | 08:55 PM
  #1592
NFSP G35's Avatar
? = 2B || !2B
When you got the 19s, did the come with the TPMS? Or did you have them switched over from the 17s?
Old Nov 3, 2010 | 10:02 PM
  #1593
NFSP G35's Avatar
? = 2B || !2B
Ok, I haz another RLQ...
What's the advantage of a metal type high flow cat over a ceramic type (or vice versa)
And which type of construction do some of the "more trusted" brands of test pipe use?
Old Nov 3, 2010 | 10:09 PM
  #1594
Wannabe6MT's Avatar
-MN G Crew-
I don't believe they came with TPMS. I am pretty sure the guy i bought them from switched them over to his wheels.
I don't know if my tpms were switched from the 17s onto the 19s. Is there any way i can check?
Old Nov 3, 2010 | 10:10 PM
  #1595
NFSP G35's Avatar
? = 2B || !2B
I'm not 100% sure, because I don't have TPMS (I'm calling it an advantage LOL) but I think the TMPS has a metal valvestem.
Old Nov 3, 2010 | 10:58 PM
  #1596
3truman's Avatar
^ yes it does! My stocks wheels have a regular rubber valve stem and the coupe 17's have metal
Old Nov 3, 2010 | 11:32 PM
  #1597
Wannabe6MT's Avatar
-MN G Crew-
As in the actual cover or what? They both looked like rubber the last time i checked... how do you swap that?
Old Nov 3, 2010 | 11:37 PM
  #1598
OCG35's Avatar
TPS stem is metal - sensor is attached to other side of valve stem (inside tire)... swapping/installing is easy once the tire is dismounted, the valve stem unscrews in 2 halves you simply screw it in the new rims... will need to have dealer calibrate them (if they are not original to the car).
Old Nov 3, 2010 | 11:40 PM
  #1599
thescreensavers's Avatar
Mr.202?
Yea the Valve is Metal on the TPMS. The shop should of said something to you? lol I bet they charged a TPMS service and they did not even swap them.
And this is how a TPMS thing looks like, (Generic Google search image)
Old Nov 3, 2010 | 11:45 PM
  #1600
Wannabe6MT's Avatar
-MN G Crew-
I dont even remember where it would have happened. Dealer charged me $30 to swap them the first time (mistake on my part) and the second time, a buddy of mine put the new tires on and swapped the wheels on for me for free.
These are the only times I havn't personally swapped them. I'll check the tires when i get home.
Old Nov 3, 2010 | 11:49 PM
  #1601
Mr.202?
^ I added some pics. But yea TPMS is stupid expensive so hope you find them :P
Old Nov 4, 2010 | 12:15 AM
  #1602
NFSP G35's Avatar
? = 2B || !2B
Well, Janik's problem solved (sorta)
so...
Old Nov 4, 2010 | 12:48 AM
  #1603
OCG35's Avatar
so...
People tend to think metal lasts longer than ceramic - in reality all HFC will go bad at some point...
Old Nov 4, 2010 | 12:52 AM
  #1604
NFSP G35's Avatar
? = 2B || !2B
^Good to know... what about in terms of flow? Is one better than the other?
Old Nov 4, 2010 | 04:12 AM
  #1605
Mr.202?
^ Berk HFC's /thread :P
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
