Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 21, 2011 | 09:31 AM
  #3091
NFSP G35's Avatar
? = 2B || !2B
Unless the camera's way off (and it doesn't look way off) it's not desert platinum, Beebo's (formerly Aaron's) G SEDAN is DP if you want to compare.
Old Feb 21, 2011 | 10:06 AM
  #3092
thescreensavers's Avatar
Mr.202?
Originally Posted by xxxxxxxxxx
dumb question but im confuse.
is the color of my car desert platinum , or brilliant silver?
Open your Drivers door, there is a metal plate there with your paint code.
Old Feb 21, 2011 | 10:32 AM
  #3093
SN00P's Avatar
CLUB MODERATOR
Lol I.saw the question when I woke up and was like hmm looks like my DG so I didn't answer it thinking it was like a trick question lolol.. but yea it is DG .. you bought the wrong color ..and how do you not know what color car you bought..lol
Old Feb 21, 2011 | 12:34 PM
  #3094
xxxxxxxxxx's Avatar
lol i know what color it is, if somebody asks me what color is your car ill keep it simple and be like its silver lol, but i wanted to know the exact color , i guess ill look on the thing thats on the door
Old Feb 21, 2011 | 12:37 PM
  #3095
Songle6MT's Avatar
I would say gray not silver.
Old Feb 21, 2011 | 06:11 PM
  #3096
kyemaul's Avatar
ok guys buying rims i like tsw new zolder 5 19 inch wheels (black) the size is 19x8 F with a 20 offset and 19x9.5 with the same 20 offset. They say for my car 40 offset it will not rub but they have it in 20 also. My question is whats the difference in the two in terms of the measurements?
Old Feb 22, 2011 | 10:02 AM
  #3097
D.Reaper's Avatar
does anyone know if there is any difference in suspension between rwd and awd suspension? looking to drop my friend's car but want to confirm i can order suspension and not have any issues
Old Feb 22, 2011 | 10:04 AM
  #3098
VincenzG35's Avatar
Almost positive it uses its own shocks/springs I even think the compression rods are different
you may also check this thread out for some answers https://g35driver.com/forums/g35-sed...uspension.html
Old Feb 22, 2011 | 10:53 PM
  #3099
VincenzG35's Avatar
whys everyone been so quite
Old Feb 23, 2011 | 12:38 PM
  #3100
D.Reaper's Avatar
so is there X specific suspension? i've looked at that thread, but i see people are running G/Z combos but dont say anything about particular suspension
Old Feb 23, 2011 | 12:43 PM
  #3101
The Stimulation's Avatar
The difference between an et of +20 and +40 is 20mm, meaning with the lower offset (the +20), your wheel will stick out nearly an inch more from the hub.
Old Feb 25, 2011 | 09:59 AM
  #3102
Sacch's Avatar
Hey guy I just noticed today that my speedometer is off by about 5-10 km/h. I was using a GPS and noticed my speed was actually lower.
To verify if the GPS was reading correctly I tried it in another car and the speedometer reading and GPS was exactly the same.
I am on stock wheels. What could be the cause of the problem?
Old Feb 25, 2011 | 10:13 AM
  #3103
NFSP G35's Avatar
? = 2B || !2B
^Speedometer.
IDK, Mine's dead on but the obd reports a slightly different speed (about 3mph lower)
Old Feb 25, 2011 | 10:44 AM
  #3104
Sacch's Avatar
yes I meant speedometer... when i get new wheels wouldnt it by wayyy off since it already is?
Old Feb 25, 2011 | 10:57 AM
  #3105
NFSP G35's Avatar
? = 2B || !2B
^That depends on if the overall diameter of your tire is larger or smaller than OEM.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
