Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Oct 24, 2019 | 11:09 PM
  #10591
Urbanengineer's Avatar
Picked up a lightly used and unrusted 350z STOCK exhaust locally. Can I just bolt my 8" extension from my aftermarket exhaust to it and call it a day?
Would prefer to not have to deal with cutting and welding extensions. Want a bolt in 350Z stock boi to G35 extension. Hope it's this easy.
Old Oct 24, 2019 | 11:11 PM
  #10592
nasch007's Avatar
G35 6MT Sport Sedan (Desert Platinum)
If you also get the 350Z intake tube (z-tube) it sounds pretty amazing as well. That part number is 16576-CD000 but you should buy a pre-owned one because they're fairly expensive from the dealership. If you get the Z-tube you will also need the 350Z PCV hose from the intake to the left side valve cover.
You could also get the Stillen intake which is a direct copy of the Z-tube but has the PCV hose location in the same spot so the original Infiniti one will work. Pretty good price on the Stillen one but you need to keep your OEM flexible coupling where it attaches to the throttle body. The 350Z intake it's all one moulded piece.
The airbox cover arrived in the mail today. I can't wait to get home and check it out. I do have the Stillen Z-tube already installed
Old Oct 26, 2019 | 04:38 PM
  #10593
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Tue only part of the system that had shorter dimensions is the midpipe. Adding the extension between the midpipe and muffler is all you need to do.
Old Oct 29, 2019 | 12:21 PM
  #10594
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
If memory serves correctly aren't the 350Z tips shorter than the ones on the G coupe muffler? It'll still fit but might not look right.
Old Oct 29, 2019 | 01:47 PM
  #10595
You are correct, they are a bit shorter. The Resonator section must be the shorter bit, or the Y pipe. I put the extension between the Y and the middy. It wouldn't make sense to go between the rear muffler and the resonator section.
I forgot the y pipe 2 bolt gaskets the first time. Screamed internally a bit lol.
Amazingly quiet now. It's nice. I miss quiet. It drone so damn much with the HKS rep. It was like 30% better with the Magnaflow mid pipe too.
Attached Thumbnails Random Little Question Thread-photo482.jpg   Random Little Question Thread-photo41.jpg
Old Nov 27, 2019 | 05:07 PM
  #10596
Zklastorin's Avatar
Infiniti G35 Sedan RWD
Debadge
I have a 2005 g35 sedan. I want to debadge the Infiniti part on it. But I heard the letters might leave an outline on your car since the paint around them has faded does anyone think this will happen?
Old Nov 27, 2019 | 05:17 PM
  #10597
calcul8's Avatar
I can haz potato?
sabertooth tiger
Welcome to the forum, Zklastorin!
I debadged mine at the dealership when I got it, and there were already some faint traces that remained for over a year. With your car, after 14-15 years of being out in the sun, the paint underneath the letters will almost certainly look newer than the surrounding paint. What you can try is remove one of the letters to see how it looks, and if it's really obvious, then put that letter back on using some plastic emblem trim adhesive
Old Nov 28, 2019 | 12:36 AM
  #10598
I'm glad after many months off this is what you came back to share . Welcome back.
Old Nov 29, 2019 | 01:35 AM
  #10599
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I took the INFINITI off my car when I bought it in 2016 when it was 12 years old. Should answer your question.
Old Nov 29, 2019 | 11:17 AM
  #10600
cleric670's Avatar
BANNED!!!
Depends on the color really, black will usually have no issue. However your clear coat will have oxidized and it gains a "yellow" tint which is noticeable on some colors, typically the brighter the color the more noticeable. Also, with newer paint I think what most people end up with is ghosting of the ADHESIVE around the edge of where the letters used to be. Proper debadging means using polishing compound and a buffer when you're done. Properly polished there will be no outline on new paint.
Old Nov 29, 2019 | 07:36 PM
  #10601
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Yeah, no outlines on mine but definitely a color difference. But I hate that huge INFINITI on the back.
Old Feb 5, 2020 | 09:26 PM
  #10602
Gemichi's Avatar
Base model G35
Hi, I just got my 05 G35 yesterday. For some reason, the brake light on the dashboard won't come on when I step on the "Hand brake". I saw online that it has to do with some kind of spring that got loosen when release too fast? How can I fix it?
Old Feb 15, 2020 | 07:18 AM
  #10603
Scorpi0's Avatar
Will 350z test pipes fit on the G35? Or are they different lengths?
Old Feb 15, 2020 | 10:06 AM
  #10604
Blue Dream's Avatar
I drove ttrank's car solo
They'll fit just fine as will HFC's and ART pipes
Old Feb 19, 2020 | 05:07 PM
  #10605
Gemichi's Avatar
Base model G35
I have two questions. I'm not sure if it is me being a noob or Infiniti do things differently that confuses me lol
1. I went to my car this morning to check on the oil level, and it was fine, but when I took off the oil cap (had to use brute force to turn it loose), it seems empty inside as picture below. Is it because all the oil has drained to the bottom?
2. Whenever I start up the car (cold/warm) and drive it for the first ten second or so, I would hear a short noise that appear to be under the steering column. Brought it to the mechanic and he said he hear nothing...here is the video
its around 00:41 might need to crank up the volume to hear the noise
Thanks a lot!
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
