Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Feb 18, 2011 | 11:14 PM
  #3061
ccc123pm's Avatar
X
youre missing the point, I only put 93 in my car...
Old Feb 19, 2011 | 12:36 AM
  #3062
OCG35's Avatar
chances are it has nothing to do with the octane or cats... crude oil contains sulfur - refining crude to gas can leave excess sulfur (but shouldn't)... if you smell rotten eggs, it's probably sulfur.
Try a different brand and see if the smell continues... or dont use that brand for a while and try in a few months and see if there is a change...
BTW, test pipes, high flow cats and OEM catalytic converters do not give off rotten egg smell... they give a burned oil/chemical kinda smell when they are new (hfc and tp) as do new after market exhausts... bad cats and used tp will smell like smog (exhaust fumes) but not rotten eggs...
Old Feb 19, 2011 | 12:46 AM
  #3063
VincenzG35's Avatar
Ok so I called my buddy for u and he said G35s run rich so pretty much every so often your gonna smell rotten eggs its the unburned fuel in your exhaust.he said carbon around the tip of the pipe is a sure sign ( only if u know ur tips polished because they all develop carbon)
Old Feb 19, 2011 | 01:05 AM
  #3064
OCG35's Avatar
^^^ carbon doesnt smell like rotten eggs, it smells like - well, exhaust/smog.
running rich smells like heavy exhaust/unburnt fuel (kinda like test pipes would smell)... I question the smell description of rotten eggs - its VERY distinctive and does not smell typical in automotive combustion.... if you ever drive by a refinery and are near sulfur unit (prilled is big mound of yellow substance) you'll know the smell of rotten eggs... if that's your smell, it is not rich a/f ratio.
Many of us have tuned ecu - I've run rich and lean (prior to a/f adjustment) - it never smelled like rotted eggs...
If you are running rich, you'll notice a definite loss in power and poor mpg... if you aren't all that familiar with the car its possible that you wouldn't perceive it... but there shouldn't be anything that would cause you to run rich.
*however, if there is too much sulfur in the gas you are running - the exhaust/carbon/whatever you want to call it will smell like rotten eggs...
Old Feb 19, 2011 | 02:16 AM
  #3065
VincenzG35's Avatar
Ok so I got my 07 at shift **** and it doesn't fit the same any ideas? The spot for the metal clips the same just it pops up when I go to press it down ??? Help would be amazing
Old Feb 19, 2011 | 07:10 AM
  #3066
ccc123pm's Avatar
X
thanks OCG, it does smell like sulfer
Old Feb 19, 2011 | 11:38 AM
  #3067
OCG35's Avatar
I'm not positive, but I think I've seen a thread or post out here where someone has a gen 2 **** on 1st gen sedan... it would probably be hard to find in a search, but try in the "look what I made/installed" thread... if I come across it I'll post a link here.
Old Feb 19, 2011 | 12:19 PM
  #3068
VincenzG35's Avatar
Ya I can't find it
Old Feb 19, 2011 | 05:48 PM
  #3069
Misfortuned's Avatar
Would you rather own a 2004 G35x with 100k miles or a 2006 G35 with 60k miles?
Old Feb 19, 2011 | 06:00 PM
  #3070
TurTLe*'s Avatar
with just those details i rather own a 2011 g37x with 3 miles on it.
how about you give us more details... like how much snow do you get and if they cost the same.
Old Feb 19, 2011 | 06:24 PM
  #3071
VincenzG35's Avatar
Agreed depends on owner previous accidets price and color
Old Feb 19, 2011 | 09:54 PM
  #3072
flyingmonkey's Avatar
In the immortal words of some guy whom I forget in the second to last Dsport DVD " My butthole is sporty, it's still a four door". O6 G35 it is, however as mentioned above details please.
Old Feb 19, 2011 | 09:59 PM
  #3073
OCG35's Avatar
^^^ his butthole has four doors??? Busy guy
Old Feb 19, 2011 | 10:08 PM
  #3074
Indeed four doors are two too many on the path to minivan ownership.
Old Feb 19, 2011 | 10:57 PM
  #3075
Wannabe6MT's Avatar
-MN G Crew-
^lol
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
