Random Little Question Thread
Old May 2, 2011 | 04:59 AM
  #3721
ilv2xlr8's Avatar
Not sure if I should put this in the tire thread but anyone run 235/45-18 and then 245/40-18? Brands aside, just curious how these two handled in comparison to each other? I plan on getting the 235/45 so I can use my stock spare because I have an X.
Old May 2, 2011 | 06:09 AM
  #3722
JBF's Avatar
JBF
the wider tread and shorter sidewall would probably be more beneficial for performance
Old May 2, 2011 | 12:17 PM
  #3723
3truman's Avatar
What's a good size spacer to run with 350Z track 18s? 15mm? 20mm? Different front and rear sizes? Front is a +30 offset and rear is +33
Old May 2, 2011 | 02:28 PM
  #3724
CG4DR's Avatar
25mm lol
Old May 2, 2011 | 04:36 PM
  #3725
JaysG35x's Avatar
What ARE THE STOCK CAMBER SPECS FOR A 05 g35x? My camber specs came back as -1.9 front left and -2.0 front right and -1.6 rear right and -1.7 rear left. do I really need a camber kit for this. just dont want to burn through my new tires to quick. thanks
Old May 2, 2011 | 04:47 PM
  #3726
thescreensavers's Avatar
Mr.202?
it should tell you on the alignment paper
Old May 2, 2011 | 06:20 PM
  #3727
CG4DR's Avatar
i am at -2.3 with no edgewear.. you'll be fine
Old May 2, 2011 | 09:19 PM
  #3728
MannyFresh's Avatar
How can i squeeze a bit of better gas mileage?
What type of mod would help?
Full tank ill do 300-310, and i know the g35 sedan is a heavy car with a big engine.
Old May 2, 2011 | 09:23 PM
  #3729
CG4DR's Avatar
ease of the gas
Old May 2, 2011 | 09:31 PM
  #3730
MannyFresh's Avatar
Originally Posted by StormTroopa
ease of the gas
i dont even let the rpm needle go over 2.
im a grandma driver........... seriously.
Old May 2, 2011 | 09:34 PM
  #3731
CG4DR's Avatar
give a little more gas. might be strugglin to get going. or do a fuel induction service
Old May 2, 2011 | 09:36 PM
  #3732
CG4DR's Avatar
Is it gay to play Star Wars with a pack of glow in the dark condoms with your buddies?
  #3733
NFSP G35's Avatar
? = 2B || !2B
^Definitively.
Old May 2, 2011 | 09:45 PM
  #3734
MannyFresh's Avatar
That could be true.
Also will be doing a tune up this week.
Old May 2, 2011 | 09:58 PM
  #3735
jeovanni223's Avatar
when i look up the 2006 coupe mid pipe from infiniti parts they only show a intermediate pipe. is that the same thing? What is the hr-y pipe called in the factory parts list?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
