Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Aug 6, 2011 | 12:32 AM
  #4576
Trickstyle's Avatar
Originally Posted by Mr.BalloonHands
depends. not faster than mine
lulz
Old Aug 6, 2011 | 02:49 AM
  #4577
Wilg35j's Avatar
A friend has one and wants to race me but i dont wanna look stupid but ill find out tomorrow
Old Aug 6, 2011 | 03:44 AM
  #4578
OCG35's Avatar
you better hope he doesn't find this thread...
If you have to ask if you're car is faster - the answer is no.
Sorry to seem insensitive... but the fact is - well, I am.
Race him if you think you can beat him... ignore him if you know you cant... If you don't know the answer - there's a chance you can and to find out, you need to race - not ask strangers.
Old Aug 6, 2011 | 06:36 AM
  #4579
Trickstyle's Avatar
Lol well a stock one vs a stock g
You can crunch numbers all day but if hes a pro driver and this is your first race, he's gunna win... pretty close, the G has 1 more hp, and is about 500 estimated pounds less... granted these are teh same cars. and you say stock but if your cars loaded w/ **** in it or u got some woofers in the trunk, thats all weight. it can win or lose you the race in some cases. GL/HF, dont get anyone killed... seriously...
2010 Acura TL SH-AWD
VEHICLE TYPE: front-engine, 4-wheel-drive, 5-passenger, 4-door sedan
ENGINE TYPE: SOHC 24-valve V-6, aluminum block and heads, port fuel injection
Displacement: 223 cu in, 3664cc
Power (SAE net): 305 bhp @ 6200 rpm
Torque (SAE net): 273 lb-ft @ 5000 rpm
TRANSMISSION: 6-speed manual
DIMENSIONS:
Wheelbase: 109.3 in Length: 195.5 in Width: 74.0 in Height: 57.2 in
Curb weight: 3900 lb (est)
PERFORMANCE (C/D EST):
Zero to 60 mph: 5.6 sec
Standing ¼-mile: 14.5 sec
Top speed (governor limited): 130 mph
http://www.caranddriver.com/reviews/...t_drive_review
VS.
INFINITI G35 SPORT 6MT SEDAN
Vehicle type: front-engine, rear-wheel-drive, 5-passenger,
4-door sedan
ENGINE
Type . . . . . . . . . . . . . . . . . . . . . . . . . V-6, aluminum block and heads
Bore x stroke . . . . . . . . . . . . . . . . . . . .3.76 x 3.20 in, 95.5 x 81.4mm
Displacement . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .213 cu in, 3498cc
Compression ratio . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.6:1
Fuel-delivery system . . . . . . . . . . . . . . . . . . . . . . . . . . . port injection
Valve gear . . . . . . . . . chain-driven double overhead cams, 4 valves
per cylinder, hydraulic lifters, variable
intake- and exhaust-valve timing
Power (SAE net) . . . . . . . . . . . . . . . . . . . . . . . 306 bhp @ 6800 rpm
Torque (SAE net) . . . . . . . . . . . . . . . . . . . . . . .268 lb-ft @ 5200 rpm
Redline . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7600 rpm
DRIVETRAIN
Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6-speed manual
Final-drive ratio . . . . . . . . . . . . . . . . . . . . . . . . . . .3.69:1, limited slip
Gear Ratio Mph/1000 rpm Max test speed
I 3.79 5.5 42 mph (7600 rpm)
II 2.32 9.0 68 mph (7600 rpm)
III 1.62 12.9 98 mph (7600 rpm)
IV 1.27 16.4 125 mph (7600 rpm)
V 1.00 20.8 158 mph (7590 rpm)
VI 0.79 26.4 158 mph (6000 rpm)
DIMENSIONS
Wheelbase . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .112.2 in
Track, front/rear . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 59.8/59.8 in
Length/width/height . . . . . . . . . . . . . . . . . . . . . 187.0/69.8/57.2 in
Ground clearance. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5.3 in
Drag area, Cd (0.29) x frontal area (25.2 sq ft, est) . . . . . . .7.3 sq ft
Curb weight . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3583 lb
Weight distribution, F/R . . . . . . . . . . . . . . . . . . . . . . . . . 53.3/46.7%
Curb weight per horsepower . . . . . . . . . . . . . . . . . . . . . . . . . .11.7 lb
Fuel capacity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .20.0 gal
C/D TEST RESULTS
ACCELERATION Seconds
Zero to 30 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2.0
40 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .2.8
50 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .4.0
60 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5.2
70 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .6.9
80 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8.6
90 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10.5
100 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .13.1
110 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .15.8
120 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .19.0
130 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .23.8
140 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .30.2
150 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .38.2
Street start, 5–60 mph . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .5.8
Top-gear acceleration, 30–50 mph . . . . . . . . . . . . . . . . . . .8.7
50–70 mph . . . . . . . . . . . . . . . . . . .7.8
Standing ¼-mile . . . . . . . . . . . . . . . . . . . .13.9 sec @ 103 mph
Top speed (governor limited). . . . . . . . . . . . . . . . . . . .158 mph
http://www.caranddriver.com/reviews/...edan-road_test
Old Aug 6, 2011 | 10:05 AM
  #4580
MannyFresh's Avatar
It's just a friendly race. If you lose... Well you lose. You win then you win. Your not gonna win everytime. If you wanna find out if your gonna win well in my eyes it's all about the driver mod!
Old Aug 6, 2011 | 10:13 AM
  #4581
MannyFresh's Avatar
Curious, are the Megan v2 resonated Test pipes different from the Megan racing resonated test pipes?
Also what other lip out there besides the n1 or wald is there for the 03-04 sedans.
Or what can be slightly customized?
Old Aug 6, 2011 | 11:43 PM
  #4582
Mr. Samster's Avatar
Originally Posted by mcaron
what did most people use to black out their window trim? I just bought the JDM window visors and have heard of some people using electrical tape, but the trim around the rear window is to big. So what have people been using? vinal?
I have visors and did black out my trim. I actually use the 3M vinyl for mine. But i installed the visors first before i put the vinyl because i was afraid when im driving the vinyl might come off and there goes my visors. I just cut pieces that are close to the trim and tuck them underneath the seals. so far its holding up, just need to redo one piece that i missed up on.
Old Aug 7, 2011 | 03:12 AM
  #4583
Trickstyle's Avatar
what trim? pictures plz :]
Old Aug 7, 2011 | 05:39 AM
  #4584
4D05G35's Avatar
Originally Posted by 3truman
I bought my pumpkin from a junkyard in CA and they shipped it for free (94lbs). Not sure about shipping to canada, I paid 250 for it, installed it myself, great mod
I got mine from a JY in Cali as well but I had to pay for shipping $300 shipped for the 3.54 pumpkin. well worth it.
94 lbs? i don't think a pumpkin weighs that much
I think the pumpkin in on the heavy side of 70lbs. Mine came wrapped in a box (5lbs packing) and IRC it was just over 80lbs shipping weight.
Old Aug 7, 2011 | 08:29 PM
  #4585
heph's Avatar
Help ID this rattle
Lately I've noticed a rattle coming from the front end at around 800-900 rpm. It happens only in drive, not in park or neutral. The car is a 2004 G35x. I took a phone video today and was hoping someone might have some clues as to what it is and how to fix it. There is a pretty clear transition at 0:32 where I let off the accelerator.
Old Aug 7, 2011 | 09:47 PM
  #4586
bbaddict33's Avatar
I'm going to get an '05 g35x in the next 2 weeks. One of the cars that I'm looking at has 18" wheels. I really like the 18" wheels, but I don't want to lose the handling in the snow. Do you guys think 18" wheels will handle well in the snow or defeat the purpose of getting the x? Thanks!
Old Aug 8, 2011 | 03:19 AM
  #4587
4D05G35's Avatar
I ran 18's on my RWD last winter and was pleased. . The car will be comparable with 17's or 18's in the snow, given the same tire type.
Old Aug 8, 2011 | 06:22 AM
  #4588
4DGS's Avatar
Can't answer the first question, not much of a megan fan but I'd assume one is the first gen, one is the second.
There's those two lips and the stillen that I can think of.... but for the price that aftermarket bumpers have gotten to you might as well just go that route.
Old Aug 8, 2011 | 06:26 AM
  #4589
4DGS's Avatar
V
P
VS.
4-door sedan
I have underlined the problem here, you're comparing a brand new TLS with the new SH-AWF to a 5/6 year old car.
BTW, had no idea the new TL is such a heavy pig. Pushin' big body status just shy of 4k
Old Aug 8, 2011 | 06:27 PM
  #4590
srv2nv's Avatar
G35 Sport
Just a quick question...
When I do up my front two windows ('03 4dr) I notice the drivers side window really slams up and down, when I go up especially it makes a pretty decent "thump" sound. It doesn't do it all the time, basically only once or twice and only when I do the AUTO up or down.
Just wondering if this is normal, or if something could be wrong? (ie. broken track, etc?!)
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
