Random Little Question Thread
Old Aug 26, 2011 | 11:23 PM
  #4681
Blue Dream's Avatar
I drove ttrank's car solo
Yeah I didn't look at that. As of right now he has 92, needs 100.
  #4682
GXXXV X's Avatar
you need 100 posts lmao
Old Aug 26, 2011 | 11:24 PM
  #4683
S 854's Avatar
Originally Posted by jake.millz32
Finally got enough posts to list in marketplace but still it wont let me. Anyone know why?
^ Well, you just bumped quite a bit of old FS threads tonight. I deleted those posts and closed the threads.
When you reach 100 posts, go PM an admin and ask them to check your account; I think the admins can unlock it manually but the system sometimes may let you do create a FS thread automatically.
Old Aug 26, 2011 | 11:52 PM
  #4684
Kayzer Soze's Avatar
Originally Posted by KING ROCKS G
am getting a rattling noise that seems to come from the muffler or muffler area more specifically the driver side on my 04 coupe when i accelerate on 1st gear and seems to go away and return when pressing the gas...anybody have any idea what this might be and what should i look for ?
I have the same thing I believe. From what I could see when testing while I stuffed my best friend under the car, my noise is coming from the flex pipe, usually when I'm in drive and idling.
The flex pipe is made of many small metal wires, and it seems that over time, the mini hair like metal fibers break and just spike up, and rattle on the underside of the car
Pardon my lack of technical terms lol.... Anyhow, that's what I found. I'm gonna try a way to "tape" down the flex pipe, or isolate it from the other metal parts around it.
Old Aug 28, 2011 | 07:15 PM
  #4685
JaE35's Avatar
Moderator
G35 Sedan
Will the rear window spoilers from a coupe (03-07) fit the sedan (03-06) as well?
Old Aug 29, 2011 | 05:50 AM
  #4686
GreenPenguin's Avatar
Noticed my radiator fan was coming on and staying on when my ac wasn't on. The temp stayed normal though on a few short trips around town. Got on the highway this morning and when I got to work I hear the fan going again and temp gauge is creeping over midway.
It's too dark right now to check my fluid level but I'll check it when the sun comes out. Anything else I should check besides that and maybe my thermostat?
Old Aug 29, 2011 | 01:05 PM
  #4687
NFSP G35's Avatar
? = 2B || !2B
Might want to try and look at the radiator itself and make sure the fins aren't clogged/bent or blocked by leaves/trash/etc...
Old Aug 29, 2011 | 10:07 PM
  #4688
NjMatteSedan's Avatar
so i finally found out the couse of my 60+ mph car vibration. It was the front spacers i had on -__- the guy said the spacers are meant for aftermarket wheels, not for oem wheels. My car drives smooth now but now i'm hella sunk, especially since i already put the oem 17"s on. Do all spacers shake? i don't wanna sacrifice comfort for looks
Old Aug 29, 2011 | 10:50 PM
  #4689
thescreensavers's Avatar
Mr.202?
^ isnt that the reason for hubcentric spacers?
My 2 year old battery died lol, but Autozone is ftw just walked in and 2 min later walked out with a new battery.
Old Aug 30, 2011 | 07:02 AM
  #4690
TurTLe*'s Avatar
Sears would test your charging system and replace your battery for free if you warrantied your battery. Of course you have to drive/tow it there
Old Aug 30, 2011 | 12:27 PM
  #4691
Trickstyle's Avatar
everyone has warranties on batteries nowadays. I got mine through Firestone back when i had my Z and my batteries still under warranty, replaced twice. and my Civic's battery is under autozone's warranty.
Old Aug 30, 2011 | 01:38 PM
  #4692
Was overheating on the ride to work this morn because of my thermostat. Took it in to the stealership and they gave me a 2009 Navy Blue G37 Sedan. Rides smoothly but the throttle response is kinda slow. Also, I had all the windows down and the moonroof back but no one was even checking me out! My 05 G has ppl breaking their necks for a peek! What's up with that?!
Old Aug 30, 2011 | 02:22 PM
  #4693
Mr.202?
Yep it was a free replacement.
Real question:
When driving over speed bumps I am hearing a knock from the front end, the anyone know what I should be looking for to fix the knocking?
Old Aug 30, 2011 | 02:56 PM
  #4694
NFSP G35's Avatar
? = 2B || !2B
^And it's not compression rod bushings?
Old Aug 30, 2011 | 09:45 PM
  #4695
Mr.202?
Let me explain more, its not getting on the speed bump its the descent.
Hit the front of the the speed bump, cars momentum gets sent up, then at the end of the bump the cars momentum comes back down.
When the car is coming back down is when I hear the knock.
So something might be loose in the engine bay, cant find anything. I need to put some padding on the hood stand maybe its making the noise.
More investigation is needed I guess need to single out which side its coming from.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
