Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #6571
Old 06-20-2012, 07:25 PM
NFSP G35's Avatar
? = 2B || !2B
^Is it a 2003? Many of them had bad compressors (mine is starting to go)
  #6572
Old 06-21-2012, 11:55 AM
jgitt's Avatar
I have several questions so bare with me. First off, is a 4 wire o2 sensor the same thing as a wideband o2 sensor? Next is where is the best place to get a wide band o2 sensor for my car? Next how hard are they to install and will it throw a CEL? Im wanting to run a fuel/air guage and was to.d narrow band was not accurate enough. Im trying to get everything together and prepped for a nitrous system and i know you really need the air/fuel guage, and a fuel pressure guage, but the pressure guage shouldnt be hard. Thanks in advance. I think i know the answer to these just want to be sure im right.
  #6573
Old 06-21-2012, 01:43 PM
CG4DR's Avatar
Ok, so my resonator in my midpipe collapsed. Now I face the decision of fixing or replacing. Always wanted the Borla or Stillen. Do I take a chance of putting a universal resonator on a Megan catback or buy a new exhaust. New Megan is $495. New Borla i've found for under $800. Should I just spend the extra $300?
  #6574
Old 06-21-2012, 02:00 PM
Subiedrewbie's Avatar
I have a stock in my garage... But I'm not sure of the shipping rates to Mars. I went n installed a coupe midpipe and it sounds and performs good. It is a huge weight difference. If you want to run a new exhaust it sounds like a good time to do so.
  #6575
Old 06-21-2012, 02:36 PM
TunerMax's Avatar
No. You can't identify the difference by number of wires.
4 wires signifies that it's a Heated O2 sensor. Unless you're dealing with an older car, you'll always see 4 wires to the O2's.
Stock O2 sensors are Narrowband
[QUOTE=jgitt;6489881Next is where is the best place to get a wide band o2 sensor for my car? Next how hard are they to install and will it throw a CEL? Im wanting to run a fuel/air guage and was to.d narrow band was not accurate enough. Im trying to get everything together and prepped for a nitrous system and i know you really need the air/fuel guage, and a fuel pressure guage, but the pressure guage shouldnt be hard. Thanks in advance. I think i know the answer to these just want to be sure im right.[/QUOTE]
This depends on the SAFC/UTEC you get. Diferent widebands output different signal referances/types and they're not all compatible with different units.
Google.
  #6576
Old 06-21-2012, 02:44 PM
The Stimulation's Avatar
IMO it's just a midpipe, just cut out the resonator and weld a pipe. It doesn't make too much of a difference, depending on what you already have. Just a tad louder. Or just put a universal resonator....or find a midpipe on the forums. You won't pay more than 80 bucks for a coupe midpipe.
  #6577
Old 06-21-2012, 05:19 PM
g35_white's Avatar
it is 2005. Will it be similar? What are your observation with regards to failing compressor?
  #6578
Old 06-21-2012, 05:20 PM
NFSP G35's Avatar
? = 2B || !2B
Nah, they fixed it halfway through 03
  #6579
Old 06-21-2012, 08:29 PM
TunerMax's Avatar
Man I'm glad my A/C is good.
NSFP, any headway on that measurement?
Thanks to Chris (Papa) in >THIS< thread I'm now aware of what the SPC spacers do, and I"ll be installing them before the month is out to help broaden the adjustment range.
Also he enlightened me that the SPC are able to adjust the caster by re-clocking the washer under the balljoint.
SPC just won pretty much all my suspension business as far as it goes due to this thoughtfulness.
  #6580
Old 06-21-2012, 10:08 PM
CG4DR's Avatar
I have the Megan already and I have my full stock exhaust too. I don't want to go back to a coupe/z mid bc I have headers, hfcs, and a ypipe already
  #6581
Old 06-21-2012, 11:13 PM
NFSP G35's Avatar
? = 2B || !2B
No headway yet. I'll remind my cousin tomorrow, hopefully he can measure it over the weekend.
  #6582
Old 06-22-2012, 06:54 AM
TunerMax's Avatar
NP dude just curious and there's a couple threads pertainaing.
After G35_papa showed me that video and more deets I'm personally good either way, but still quite curious about it.
Would be nice if the guys can just grab a 350Z upper arm rather than dishing out for the SPC with moderate drops.
  #6583
Old 06-22-2012, 08:45 AM
Racer M's Avatar
where to buy rotors?
Ive got an 05 sedan, the stealership wants 260 plus for the front pair...i'll pay it if necessary, but i would think i could them a tad cheaper on the net.
  #6584
Old 06-22-2012, 02:24 PM
TurTLe*'s Avatar
^ rotors can be found anywhere.
I consider rotors a throw away item. You can go with centrics,
Amazon Amazon
something like that, or some of these guys spend some coin on brembo blanks off tirerack.
I personally always opted for the cheapest name brand out there, most cases it would be centric's CTEK line, raybesto, EBC. Never had issues unless i reuse them with a 2nd set of pads.
  #6585
Old 06-22-2012, 02:35 PM
thescreensavers's Avatar
Mr.202?
Centric Blanks
The Fronts are Part Number 120.42080
They are 140 for the front pair.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
