Random Little Question Thread
#6556
and the compression rod, the upper control arm, but they'd be wrong,
he couldn't be further from the truth saying they are the same....
let me know if I can help ya out!
Phil
#6557
#6559
Would changing my "HR-like" Y-pipe to a M2 HR Y help reduce this weird rasp that I'm getting?
It sounds like there's loose metal rattling, when I hit the 2800-3100 RPM mark.
My setup as follows:
Berk TP 2.5"
To Y inlet 2"
to Y outlet 2.5"
Mid pipe 2.5"
Muffler 2.25" to 3"
I know I won't get rid of all of it.
I figured getting rid of that 2" to 2.5" change in my Y to at least a 2.5" to 3" would help with the rasp in the center of my car. I know I have rasp in the muffler section but it doesn't sound as close as the rasp I hear coming from the center of my car
Berk TP 2.5"
To Y inlet 2"
to Y outlet 2.5"
Mid pipe 2.5"
Muffler 2.25" to 3"
#6560
Received 1,939 Likes
on
#6562
Hey I'm going to install my tokico blues tomm and work my axel click issue I have a few questions...the TSB for the axel says to use M77 grease pep boys autozone and struss don't carry it anyone have a reccomendation? Next I got a feeling that my spindel bushings are gonna be blown because that's just my Luck (hope to god there not ) but if so what can I do to fix it tomm I travel a long way to use my uncles shop and ill only be here for the day?
And Mitrov I just went through Phil @ Grubbs for some parts great customer service fast shipping I high reccomend using Grubbs!
#6563
#6565
^ Sorry I dont know that info, I just bought them from the dealer they were pretty expensive for cotter pins. I was told afterward by friends that you can buy them at Advance and Autozone, But I don't have a size for you.
Do you have the service manual?
http://www.notre350z.com/forum/files...ClickClack.pdf
http://ww2.justanswer.com/uploads/ba...ITB05-002b.pdf
Cotter Pin is P/N 40073-0L700
Id call around to see if any local Nissan/Infiniti dealer has it, or you can talk to the dealers on here like Phil@Grubbs who will give you much lower price then 99% of the dealers out there.
#6566
#6568
#6569
#6570
I have a peculiar problem. When running AC after 2-3 miles, the rpm increases to 1200 rpm when we lift off the accelerator pedal while driving. Previously, it use to fall around 1k rpm or less. But now it stick to 1200 rpm and so it keeps maintaining the pace. Eg i am going at 40 mph and i lift my leg, the revs usually fall to 1k rpm or less, if AC is running, it sticks to 1200 rpm. Also while idling at stop it is around 900 rpm. Isn't it unusually high. Also the noise from the compressor is a little to loud than normal. I mean, it is so loud it can be heard 2-3 cars away in traffic. This is my first proper summer with G35 what with temperature reaching 100 F and more, so i am not sure if this is normal.
I recently had a throttle body actuator error but after I reset the code it didn't come back. But i have observed the above. Is something wrong with the car? I have got a quote of $99 for cleaning throttle body from infiniti dealership. Should i get it done. i am afraid it may damage some other stuff.
Please advise
Please advise
