Random Little Question Thread
#6872
#6873
on
^Exceptionally large calipers without changing the diameter of the rotor does little if any good.
The 05/06 brakes being an upgrade is only partially due to them being dual-piston as opposed to single piston... it's also an upgrade because the rotors are close to an inch larger in diameter.
Another example would be Miata brakes. There are some years that came with 1" larger rotors, the calipers are the same, just spaced out more to make room for the larger rotor.
Even with the same calipers, the larger brakes are a huge upgrade (that's also a bolt-on) for cars with the older setup.
#6874
Seriously>?
![Bowrofl](https://g35driver.com/forums/images/smilies/bowrofl.gif)
In case you are serious, these brakes are the SPORT package brakes (something like that) for the G37, and they're the same on the 370Z though on the Z they're black with NISSAN written on them.
#6878
how to increase ride height?
hi everybody, I'm new to this forum and need some help for my G. i got a 2001 skyline V35 sedan 2WD, which is same as infinity G35(which is stock car ,nth has been changed). i wanna increase the ride height like 1 or 2 inches just the front. any suggestion or tips. thank you
#6879
![Confused2](https://g35driver.com/forums/images/smilies/confused2.gif)
welcome to the forum
#6881
actually, i'm from Myanmar and road here is like a moon face. every time i went over speed bump , mud guard scrape off and can't ride with 4 ppl include the driver. the car will sit so low that i was one time stuck at a rail road crossing. have to lift from back and the train was coming rite at me.
#6882
terryphyo (08-09-2012)
#6883
Out of nowhere I have so much brake squeaking. Probably time for new pads. I'm thinking of either getting new rotors or getting the current ones resurfaced. Only reason why, on the way to Vegas, high temps, not too much braking, but at one downhill area I was applying the brakes, and not too hard, and the entire car was wobbling and shaking. No issues since and I was doing about 80 mph, still do that, but flatter roads.
Anyway, thinking about Hawk Pads. Curious on suggestions for rotors, thinking perhaps drilled? Also thinking about maybe upgrading to SS lines, not quite sure yet. Say for a budget of 300-400, what would be some good options?
#6884
SS lines are great as they stiffen the feel of the brake pedal and probably adds a slight response to the braking.
And although they aren't horrible, I am not a fan of Hawk Brake Pads. I forget why I didn't like them, but I prefer using Project Mu brake pads much more these days.
The Stimulation (08-15-2012)
#6885
