Random Little Question Thread
#6857
I can haz potato?
you can get the basic kit with blank rotors for 1500-1600, the full on kit is only 1800ish with stainless lines.
I went for the middle-ground, but with shipping to me in Canada this was around $2k.
FYI, I had one caliper dinged up, and one scratched, CZP seems like they'd honour this through Infiniti /Nissan but the hassle is huge, I'm hoping they'll show some good will and just give me a discount.
#6860
Im pretty sure the only calipers that fit the stock rotors are the calipers your car came with. If you are looking for a less expensive upgrade you can consider 2 piston brakes from 05+ Gs. The calipers look pretty much the same though, but the rotor is slightly bigger.
#6863
then you need pads rotors and the calipers with all the Pad hardware. Might be worth pricing out individually, but I doubt that you'll save money buying it separate when you can get it all for around $1600 if you're in the states.
Absolutely need all of hte above no matter what if you want those calipers.
