Random Little Question Thread
Old Nov 3, 2012 | 11:50 AM
  #7621
MPG35fiend's Avatar
ionic dynamics might still have some of those.... check under market place.
Old Nov 3, 2012 | 12:12 PM
  #7622
Muney2bmade's Avatar
I wanna say it's their emblem-less grille, or just an emblem-less grille in general lol. Just the way it matches the car looks super sick I guess.
Old Nov 3, 2012 | 12:33 PM
  #7623
MPG35fiend's Avatar
yes it is its a DIY... theres a thread on it on the DIY section.. thats where i looked to do mine... lol.
Old Nov 3, 2012 | 01:26 PM
  #7624
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by MPG35fiend
ok. =( found a solution...!!
looking into forged star F14s Deep concave wheels. 19x10+20 all around.
I approve of this post
Old Nov 5, 2012 | 08:51 AM
  #7625
SuperTrooper699's Avatar
Hey guys I'm running 15mm spacers with my wheels now can barley fit a credit card between the tire and fender. I'm getting my rears rolled this week. Could I expect to fit like 25mm spacers then?
Old Nov 5, 2012 | 08:57 AM
  #7626
DVG's Avatar
DVG
Originally Posted by TunerMax
As for a broken seat! Wow. I'd be going to the dealer for that repair, that's a safety item, they have to fix it.
I could see where the weld had snapped clean though, it just made the seat wobbly, not really loose. A dealer wouldve told me to replace it I bet haha
Old Nov 5, 2012 | 09:17 AM
  #7627
TunerMax's Avatar
G35
The cost of each wheel to break down is roughly 150-300 a wheel and powder coating would be 100-150 a wheel.. So I have to find out tomorrow ..
Can't you handle this yourself? It seems like a simple procedure that could be done with the most basic of tool sets and experience. I could be wrong though, never done them. Might be something to consider though?
well it doesnt look too bad at all... i thought i would look a lot more noticeable...
Just a basic extension of the sunstrip that is already there, and a little darker to match the rest of the tinting. As long as it isn't to big it's normally a nice clean addition. I am still curious to see a full shot of this on a G though before I decide I want one
Old Nov 5, 2012 | 02:24 PM
  #7628
Anyone know anything about the Takeda short ram intake? First day I brought my G out to a racing kind of area, someone said Takeda is the best way to go. Probably just like any other intake but any input?
Old Nov 5, 2012 | 02:31 PM
  #7629
calcul8's Avatar
I can haz potato?
sabertooth tiger
Stick with your stock setup or get a z-tube
https://g35driver.com/forums/intake-...s-results.html
Old Nov 5, 2012 | 04:40 PM
  #7630
MPG35fiend's Avatar
i would lean towards no... you may want to consider getting a pull or cambering more to make fitment better.
but if you must put 25mm on you could make it fit by adding more negative camber.
yes its very simple to do, but its super tedious and takes HOURS of work. plus i sold my oem and previous set of wheels and dont have anything to sit on =( i wouldnt want to go through it myself.. hahaha. the ppl that did my reseal told me that theyll never take up another 3pc sandwiched face again... if it was hard for rim repair professionals to do it then im sure it would be harder for me 10 fold!... lol no thanks!
dude i was trippin about that whole color match thing... i just wasnt use to it color matched and was having second thoughts, but the more i research it and look at other sedans i feel better about doing it! the only thing that i would of done differently is probably painting the window trim gloss black. but then again a lot of sedans are doing black... so at the end of it all it was pointless doubting my decision.. and i still plan on getting a new set of wheels....
Old Nov 5, 2012 | 07:10 PM
  #7631
TunerMax's Avatar
G35
Good call, tedious work sucks, but even more so if you're rushed because you have no back up wheels!!
I do think the colour match is a good call, it's just the window visors that throw it all off because they're black. I am super curious what it would look like with them removed.
Old Nov 6, 2012 | 09:49 AM
  #7632
DVG's Avatar
DVG
I'll Paypal you 10 if you never tint your head or tail lights.
Ill paypal you 10 if you find out which relay pin I have to isolate to disable only DRLs and nothing else
At this point Im considering rewiring it so that
The original high beam wire is connected to a relay that powers new DRLs
The fog light wire is connected to high beam
So I would lose my fog light, and I would use my fog light switch to turn on my high beams.
Old Nov 6, 2012 | 02:04 PM
  #7633
TunerMax's Avatar
G35
Ah leave that stuff alone!
Use the factory setup, it'll be much cleaner and actually easier.
Correct if wrong:
WANT:
- High beams, fogs and Low beams function as normal.
- DRL's still work, but don't illuminate the headlights at all, instead, they light up your auxillary lights (LED's?)
If everything I'm deciphering is correct, you should be able to add a CHASSIS GROUND to the RIGHT headlight High beam Ground wire, and tap into the High beam OUTPUT from the DRL module, which is Pin #6.
Your stock DRL diagram:
Modifying:
Modded:
However, there is one issue with this setup, when your HIGH BEAMS are on, the DRL's will turn on also. If that's no problem, then wire as above. If you dont' want that, then we might have to throw a relay into the mix. The above is the easiest method, and you dont' lose fog lights.
I can tell you how to do it the way you mentioned also, but IMO, there's not much point to doing it that way unless you want to completely disable the DRL's and run your AUX lighting off a separate switch completely.
Old Nov 6, 2012 | 02:08 PM
  #7634
DVG's Avatar
DVG
You de best!
Yeah, I would actually want the DRLs all the time idealy, so my plan before was just to wire it to something like the cig lighter. Ill review this when I get home and see if it makes sense to me
Oh, and FYI, I ordered these badboys: http://www.v-leds.com/V3-TRITON-6K-W...-p9815099.html
They are 1/2 as bright as a halogen low beam on white mode, in the turn signal area! I think that will suffice as DRLs
Old Nov 6, 2012 | 02:11 PM
  #7635
LxV Socal's Avatar
Can't find the OEM replacement g35 headlights :(
I've been searching and searching but all I find is those lame chinese aftermarket projectors for the coupe.is there any place that still has them in stock? I realize it is a discontinued item
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
