Random Little Question Thread
Old Dec 8, 2012 | 03:58 PM
  #7861
driftsucky's Avatar
Originally Posted by grdane101
im wondering if i am able to get 19 inch wheels.
Tire patch increases handling. If you take a look at higher end sports cars, you'll see larger diameter and wider wheels. I mean, ALL of the things you asked could be quickly found out by searching. But, since we're already knee deep, there's an actual thread called the 19" discussion thread and it shows 19" wheels. In the 'for sale' section, there's a section of wheels...within that wheels section, there's a 19inch section...with 19inch wheels that fit our cars. Get'r'dun
Old Dec 8, 2012 | 04:29 PM
  #7862
doodos's Avatar
Big Question
I have a question that i need to be answered. I have been looking everywhere and can't find a solid answer.
I have an 03 g35 sedan and my RH side lower control arm is bent and I need a new one.
I have been searching everywhere and can not find one. I went to orielly, autoparts, and autozone and they all have a lower control arm but its for the coupe and they have no sedan in the system for one.
Question is, will the 03 g35 coupe lower control arm also fit an 03 sedan?
Here is a picture of mine so we know what part it is just incase there is confusion.
http://postimage.org/image/jcm602sy3/
Old Dec 8, 2012 | 06:37 PM
  #7863
socialconflicts's Avatar
Coupe and sedan would be the same, even the 350z should be identical. most of everything under the hood that fits the coupe will fit the sedan.
Old Dec 8, 2012 | 10:39 PM
  #7864
nascarbuff17's Avatar
ATTN G35 Gurus...
Hello all, thought I would share some issues I am sure you have all had in the past and looking for answers.
First and foremost, My G35 will not shift out of park (unless I override the shift lock) and I here a clunk when depressing the brake pedal while starting the car. I also have no brake lights. When I scan the car, I get a C1142 brake pressure sensor error. I tested all my fuses with a lead and they are fine. My VDC, Slip, and ABC light is on (however, all work fine) When I use a test lead on the switches below the steering column I can activate them, shift form park and I have brake lights. I am all out of ideas.
Also, cruise control has recently stopped working, and the set light just flashes when turned on.
Old Dec 9, 2012 | 06:22 PM
  #7865
ajw2495's Avatar
Question Stock Sedan Spoiler w/ Brake Light
hey. My 2006 Sygan has the stock spoiler with the built in brake light in it. I'm debating whether to remove it and put on the smaller trunk lip. Is it bolted in or is it just taped on? i dont want to remove it just to find out that there are holes in the trunk. thanks!
Uploaded with ImageShack.us
Old Dec 9, 2012 | 06:30 PM
  #7866
Mustang5L5's Avatar
Every problem ypu described is linked to the brake switch.
You can't shift from park, activate the brake lights or use cruise without a function brake switch.
When you depress the brake pedal. Do you hear a click in the center console area?
I'm not sure how the brake switch is connected to the pedal, but I'm guessing this is a good place to start.
Old Dec 9, 2012 | 06:34 PM
  #7867
Mustang5L5's Avatar
It's bolted on. Your best bet is to find someone with an identical trunk lid and swap lids.
Personally, I think it looks great as is. I wish my '06 had the OEM wing
Old Dec 9, 2012 | 06:36 PM
  #7868
Mustang5L5's Avatar
Autoparts store computers tend to not be the most accurate when it comes to what parts fit what.
Old Dec 9, 2012 | 06:41 PM
  #7869
ajw2495's Avatar
uhhhhhh mannnnn. thanks though.
Old Dec 9, 2012 | 11:20 PM
  #7870
Muney2bmade's Avatar
Anyone know the difference between these two carbon fiber hoods and an explanation why one is more expensive than the other?
http://www.carid.com/2006-infiniti-g...d-1299083.html
http://www.carid.com/2006-infiniti-g...it-305528.html
is it just the name or what?
Old Dec 9, 2012 | 11:24 PM
  #7871
TORETTO's Avatar
one is seibon. the other is not seibon.
  #7872
Drew113's Avatar
Ban Hammer Expert
build quality usually
Old Dec 9, 2012 | 11:27 PM
  #7873
Th3R3dStar323's Avatar
Why do women insist on talking about football like they know what is actually going on? Please just shut the **** up. I am sitting here listen to this ***** try and explain to someone on the computer what is going on with the Green Bay and Detroit game. My ears are ****ing bleeding I swear.
Old Dec 10, 2012 | 03:58 AM
  #7874
j.dmcar's Avatar
aftermarket lugnuts set + wheel locks
hey what kind of lugnuts+wheel locks set you guys recommend? i want something very good. thanks!
Old Dec 10, 2012 | 08:35 AM
  #7875
TunerMax's Avatar
G35
this is the sedan section. You might want to ask the coupe guys, those hoods don't fit our cars
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
