Random Little Question Thread
#8553
nitrous and methanol.
nitrous system will be a wet system.
on here before I was told I'd want to place jets before Maf sensor. won't the fuel mess up the Maf sensor?
if so, should I place the nitrous jet before the Maf sensor and the fuel jet after it?
and if I run methanol the same time I run nitrous,(both injected at once) will it be bad? or better? or will it not matter?
if it is better that I run meth with nitrous, should I place the meth nozzle before or after Maf?
thanks in advance.
thanks in advance.
#8555
thanks in advance.
thanks in advance.
#8556
I'm going to put it 6" from the TB. I've read that's the best part to put it.
and I will be spraying with gas. I'm thinking 100 shot. 75 on the fuel side and 25 on the nitrous side..? or is that completely backwards? or is it safer to push 75 shot. 50 fuel, 25 nitrous?
and you're saying. not to use meth Injection if I'm using fuel?
#8558
pff, when am I wrong?
haha.
I was gonna say, those damn second gen guys getting all the good stuff lol
#8559
#8560
It's a helmholts resonator, it conceals out specific frequencies in exhaust sound. Look it up and read on it, it can get very technical. It's the simple idea of altering the the exhaust noise as it passes over it, kind of like when you blow air over a glass bottle.
fchdx (02-09-2013)
#8562
TunerMax (02-09-2013)
