Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #8611
Old 02-13-2013, 02:36 AM
g35indafuture's Avatar
I'm planning on buying tokico hp blue shocks to go along with eibach pro-kit springs for coupe 03-08...should i stick with tokico hp blue shocks (sedan) or go with the tokico hp blue shocks (coupe) 03-08 to go with the coupe setup...will the springs work on both of the shocks?
  #8612
Old 02-13-2013, 11:18 PM
JDMswagSerf's Avatar
Originally Posted by G35Papa
Removing the mirror assembly from the car is easy. I didn't have to de-pin anything as my shop was able to work with the harness being pulled through as much as possible.
Take a look at this thread to see what needs to be done
https://g35driver.com/forums/interio...ew-mirror.html
As for the window trim, It's not really easy to explain. The pieces are thin and prone to bending/creasing easy when removed. I had to replace two of them because I damaged them during the removal.
thanks for that info. but I think I'm just going to plastidip both parts. it'll be faster and still give me some glossy black.
hey is there a fuse for the mirrors somewhere?
my mirrors don't work/move with the ****.
  #8613
Old 02-14-2013, 10:57 AM
617DG35x's Avatar
Does anybody know where I can get nisrookie sideskirts? Also would anybody know if nisrookie sideskirts hang lower than nismo ones? I have a OEM awd bumper with the oem lip and don't want the skirts to hang lower than the front lip. Any input is appreciated.
  #8614
Old 02-15-2013, 04:30 AM
idk where I saw this.
but where is the info/thread on how to make your automatic g35 pedals look like manual g35(shift pedal) and something to do about the foot e brake...
can someone please direct me to it please.
  #8615
Old 02-15-2013, 08:32 AM
DVG's Avatar
DVG
DVG is offline
Hey everyone
I just repainted my rear badge, and broke off the 2 placement tabs. I want to relocated it about 1" lower. The holes in the trunk will be covered, but I am still somewhat worried about the holes getting exposure to water/salt and getting rusted.
I am thinking I should put some white silicone on the holes to protect them from rust before putting the badge back on.
  #8616
Old 02-15-2013, 10:47 AM
Originally Posted by DVG
Hey everyone
maybe you could get a little grinding stone in the hole and clean it up then paint over te part you cleaned.
  #8617
Old 02-15-2013, 10:50 AM
DVG's Avatar
DVG
DVG is offline
How would making the hole bigger help... Im just looking to protect it from rust
  #8618
Old 02-15-2013, 11:01 AM
Peoria35sedan's Avatar
Hey everyone
The holes should have paint on them so a little clear silicone couldn't hurt.
Keep the grinder in the tool cabinet
  #8619
Old 02-15-2013, 11:06 AM
a very fine stone would have not made the hole bigger or messed with the diameter. think of it as a small round sand paper ball. it would have sanded off any junk that is in the hole then the paint would protect it
if it doesn't have rust or anything then just oust the silicone. if it has rust, you needa take the rust off first.
  #8620
Old 02-15-2013, 11:26 AM
DVG's Avatar
DVG
DVG is offline
Oh, now I see what you're saying. There isn't any rust right now, I'm just being proactive
  #8621
Old 02-15-2013, 12:50 PM
mpugeda's Avatar
Gentlemen,
2005 Infiniti G35 Sedan (6MT) lowered on eibach prokit
Is any modification required to fit 8.5 +20 upfront (225/40/19 OR 235/40/19 tire, haven't decided yet)
Thanks in advance for any input
  #8622
Old 02-15-2013, 02:00 PM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
You just need to buy the OEM sport pedals and install them. If you get the set for a 6MT you can use the clutch pedal to cover your e-brake pedal, but I believe it will need to be glued or screwed in. The rest of the pedals replace your stockers.
http://www.ebay.com/itm/INFINITI-G35...be97e0&vxp=mtr
  #8623
Old 02-15-2013, 03:00 PM
g35_white's Avatar
I left my keys with fob inside the car. i locked it from outside. any way i can retrieve it? the trunk button also doesn't work. any help would be appreciated. thanks
  #8624
Old 02-15-2013, 03:31 PM
Dr3w5ki's Avatar
Originally Posted by mpugeda
Gentlemen,
Nope. I have an 8.5 +25 up front with a 245/35.
mpugeda (02-15-2013)
  #8625
Old 02-15-2013, 06:18 PM
TunerMax's Avatar
*** long as you use a constant strip of double sided tape on the top half you will be fine dvg, methinks.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
