Random Little Question Thread
#7111
I have an 03 sedan, which you may know has the silver painted plastic interior door handles (im not talking about the trim that you use to pull the door shut that could have been wood, im talking about what you use to open the door from the inside, where the lock is). I've seen in pictures that the 06 has a chrome looking door handle. Can anyone confirm that this is actual METAL and not just shiny plastic?...I HATE the plastic-feel of mine and I think the swap would be a cheap easy upgrade. Bonus points if you know where to get some.
#7112
no interior lights
i need your help guys my map light, rear individual lights, ligths at the bottom of the door and key ring light arent working. everything else in the car works fine headlights,brake light, side markers gauges, ac display, clock everything is perfect. i checked the fuse box in the kick panel had the cigarret lighter fuse blown but i replaced no other blown fuses. cheked the fuse boxes in front and in back of battery and all fuses are ok. disconnected the battery for 30 minutes and nothing. i also checked the bulbs to make sure there not blow but there fine. the weird thing, my sunroof switch still works. cant think of anything else to check. any help would be helpfull thanks
#7113
#7114
I drove ttrank's car solo
Received 1,486 Likes
on
#7115
#7116
Would it be worth my while to post an ad on CL (trade 4dr auto for 2dr coupe)
??? Thread title. Basically i have a 4dr sedan automatic that i want to be a 2dr coupe. MT would be a good plus to it, tired of looking like the other countless g35's on the road i see being driven by asian ladies (No racist)
100k miles everything's clean as a whistle.
#7117
#7119
#7120
on
#7122
Received 1,939 Likes
on
#7123
