Random Little Question Thread
#8600
If I was looking for an aftermarket shift ****, would there be a thread/pitch to look for? Or at least something indicating fitment?
#8603
Perfect place for this - Does anyone know if the plastic piece on the front underside of the passenger seet is held in place by screws or those plastic retainers? I noticed that piece loose ('04 g35x sedan) last night. It is too cold and dark when I get home to really look it - or I'm lazy...
#8604
#8605
Orrrrrrrrr a short in your horn wiring.
#8606
I drove ttrank's car solo
Received 1,486 Likes
on
My guess is one of the 2 fuse boxes in the battery compartment got wet and is causing the issue. You'll have to take out the battery to get to the back box.
#8607
Thank you
I removed the trim and had it painted at a shop. If you look at you mirror, it's two pieces, the one containing the mirror and the other part it pivots on attached to the door. I had the part attached to the door painted gloss black to match the trim.
The wing is a Wald Bison lip from a Mercedes that was molded into the trunk.
I noticed mine today and it was light faded gray.
to remove it I pop the inside cover off and in screw it?
how did you remove the window trim too?
#8608
I broke one of my mirrors when I was trying to get the mirror out (I wanted to paint the mirror cover and base black) I settled for just the base.
#8610
Take a look at this thread to see what needs to be done
https://g35driver.com/forums/interio...ew-mirror.html
As for the window trim, It's not really easy to explain. The pieces are thin and prone to bending/creasing easy when removed. I had to replace two of them because I damaged them during the removal.
