Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
  #9271
Old 06-24-2013, 05:04 PM
MrTBahgs's Avatar
Trying to bump this post once to see if I can get a response, otherwise I'll just ask the dealer when i get my next service done.
Originally Posted by MrTBahgs
2006 G35X with about 86,000 miles.
I dont use my manu-matic mode too crazy often, but every now and then I have an issue when trying to downshift and Im not sure what would cause it since it isnt consistant. I will try and continue to test it further and pay more attention to when it happens, but for now maybe I can get some help with the information I have currently.
As far as I know, only when I try and downshift I will sometimes have the transmission do nothing. I recall it almost always happening when trying to go from 4th to 3rd and no matter how i move the shifter it just acts like I didnt touch a thing. Going back up shifting and I think it works perfectly, but during the times it wont downshift the only way it does drop gears is when i slow down enough for the RPMs to drop way low and it forces itself to auto downshift. I think after it does downshift I might again have the problem going down to 2nd. Then it usually works fine again after going back up.
This may only happen once during a full driving session and doesnt always happen. It only has happened in the middle of a driving session, never been the very first time I try and downshift when in manu-matic mode.
Im not sure how the whole system works, but could there be some sensor or something in the stick that is dirty or has bad contacts to not register my downshift? I initially considered it to be a wiring or grounding problem, but with it so inconsistant and rarely happening I wouldnt think thats the issue.
Is this something thats best to explain to the dealer so they can look into certain components for possibly a quick fix?
Its not like its an immediate need to get fixed since everything works fine when in drive, but this would be nice to have working correctly so I can drive in manu-matic whenever I want and not be annoyed by it.
  #9272
Old 06-25-2013, 10:42 AM
terryphyo's Avatar
does any of front suspension parts form 2003 g35 coupe (compression rod, lower control arm and upper A arm) fits on a 2003 sedan? please help me out guys, thx
  #9273
Old 06-25-2013, 11:51 AM
NFSP G35's Avatar
? = 2B || !2B
All of them should fit
terryphyo (06-25-2013)
  #9274
Old 06-27-2013, 08:17 AM
Rob902's Avatar
Hey guys just wondering if anyone has tried this combo for mods on their g sedan ? : stillen intake\ z-tube + plenum spacer+kinetix HFC + stillen gen 2 exhaust. I'm ready to install these soon, can't find any videos on this combo. 2004 g sedan. I was looking for a deep but not too loud and raspy sound.
  #9275
Old 06-27-2013, 01:07 PM
Sacch's Avatar
Anyone knows where I can find front and rear Mud/splash guards for 05-06 g35 sedans?
  #9276
Old 06-27-2013, 01:20 PM
NFSP G35's Avatar
? = 2B || !2B
^Junkyards, ebay or the marketplace here are your best chances. The factory doesn't make them anymore.
  #9277
Old 06-27-2013, 04:01 PM
Peoria35sedan's Avatar
CZP lists front on their website
http://www.conceptzperformance.com/C...3208.16.136.53
  #9278
Old 06-28-2013, 11:48 PM
yoyoyo8's Avatar
Lowering my 05 sedan with 350z revised suspension I will need a set of SPC rear toe bolt?
  #9279
Old 06-28-2013, 11:49 PM
calcul8's Avatar
I can haz potato?
Received 1,019 Likes on 793 Posts
sabertooth tiger
Need, no. Want, it's probably not a bad idea.
  #9280
Old 06-29-2013, 01:52 PM
SooWoo's Avatar
Whats up guys...i have an 05 g35x sedani need to change my cats i belive (some input plz) im getting the codes P0420 and P0430. (Catalyst system efficency below threshold bank 1 and the other is the same but bank 2) any opinions ? Also i was wondering if AMS 350Z/G35 HIGH FLOW CATALYTIC COVERTER will fit on my sedan ? Some help plz
  #9281
Old 06-30-2013, 06:52 PM
Airic214's Avatar
how do you take off center caps?
  #9282
Old 06-30-2013, 06:53 PM
Plur's Avatar
push it out
  #9283
Old 06-30-2013, 06:54 PM
calcul8's Avatar
I can haz potato?
sabertooth tiger
Originally Posted by Plur
push it out
This. You can do it with your fingers or knuckles, or if you're afraid of hurting yourself, gently tap them out with the handle of a screwdriver or something similar.
Airic214 (07-01-2013)
  #9284
Old 07-01-2013, 03:41 AM
Airic214's Avatar
guys what is your opinion on the 2004 acura tl compared to the 2004 g35 sedan ? before i purchased my 04 sedan, it was a decision between the tl. i want to know what are your opinions.
  #9285
Old 07-01-2013, 03:55 AM
TORETTO's Avatar
Received 1,939 Likes on 1,249 Posts
fwd vs rwd.
need i say more
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: Random Little Question Thread
