Random Little Question Thread
Old Jul 18, 2013 | 04:52 AM
  #9376
G_DiRTY5's Avatar
Originally Posted by DVG
Yeah, that output is screwed up. The hotspots arent where they are supposed to be either. There is no reason it should be like that. Can you link me to the link you bought the bulbs from?
There are really only 2 things that could cause this:
1. Improperly seated bulbs (More likely)
2. Cheap bulbs that dont have the focal point in the right place. i.e. the arc chamber is in the wrong place on the bulb, or the bulb is really angled.
Judging from the wall shots, it looks like it might just be the left lamp that is nasty. The hotspot is in the right place on the right and I think I can see a proper cutoff on it. Try standing in front of each headlight to block light and seeing what the cutoff looks like from each bulb.
Alright I'll take another wall shot doing each head light separately.
Here is the place I get my HID's and LED's from:
http://www.mtrinternationaltrade.com/index.cfm
I always go here because he is literally 5 minutes from my home and if something goes wrong I can always go back to him and get a replacement. Super nice guy too!
Old Jul 18, 2013 | 05:06 AM
  #9377
DVG's Avatar
DVG
Given the price, they are aftermarket bulbs, which are hit or miss in quality. While they arent "fakes" because they arent philips branded, you can reference this real/fake philips bulbs to judge overall quality of the bulb: http://gearheads.in/showthread.php?9...nuine-are-they!
Old Jul 18, 2013 | 05:30 AM
  #9378
G_DiRTY5's Avatar
Wow that link has some really good info in it, I bookmarked it for future reference. I'll take a good look at my bulbs when I adjust the clips for them later today, maybe even take some pics of them too haha.
You've been really good help I appreciate it!!
Old Jul 18, 2013 | 06:07 AM
  #9379
DVG's Avatar
DVG
No problem, the main thing you are going to want to look for is the arc position (The glass ball in the centre - compare that with old bulbs and the angle. Should be prefectly 90 degrees with no bias towards any direction. Most of the stuff in that link I provided is just stuff that doesnt really matter, but can help identify fakes.
Old Jul 19, 2013 | 10:09 PM
  #9380
TORETTO's Avatar
Can anyone recommend a brake fluid when changing from regular brakes to BBK? I'm going to be topping it off while bleeding. Going with either the OEM Nissan DOT 4 or Motul RBF600.
Leaning towards Motul. It will mix with the factory stuff already in my system correct?
Old Jul 20, 2013 | 12:04 AM
  #9381
totopo's Avatar
ate super blue/200 is a lot cheaper
Old Jul 20, 2013 | 12:08 AM
  #9382
TORETTO's Avatar
^ forgot all about that. haha.
Well I may go with that instead.
Old Jul 21, 2013 | 07:18 AM
  #9383
NeverTooFast's Avatar
17 years old so mind my stupidity, I have a plenum already on the car, I wanted to add berk hfcs with maybe an hks exhaust, is this good enough or would it be better to also add stillen headers, cai, with a dyno tune? I'm 17 so if there's a better / cheaper way to get better gains please don't hesitate
Old Jul 21, 2013 | 08:35 AM
  #9384
Blue Dream's Avatar
I drove ttrank's car solo
Best mods for gains not forced induction:
Plenum spacer (you have)
ART pipes (better than HFCs but won't pass the sniffer test if you have them for inspections)
Aftermarket exhaust system (HKS is only a muffler and provides no gains)
CAI (R2C is my recommendation because it seals against the hood to prevent heat soak)
Dyno tune
Headers aren't really worth the money because gains are limited unless you add cams to the mix. Just know though, that the gains from all of these mods will be modest compared to the money you'll spend. If you do all of the above you might see 50HP if you're extremely lucky but will spend close to $2000 getting all of that if you buy new.
Old Jul 21, 2013 | 02:33 PM
  #9385
Dyno tune
Appreciate the feedback, would trying to get lighter pistons make any noticeable gains or is that just a waste? I long for a day FI becomes cheap, $5000 is not easy to come by at my age :-[
Old Jul 21, 2013 | 02:51 PM
  #9386
TORETTO's Avatar
Lighter pistons?
Anything on the G35 is a waste. The car is slow.
Old Jul 21, 2013 | 03:02 PM
  #9387
Wi-Z_Sam's Avatar
Btw so you know, $5000 will not get you FI
Double it then you will be
Old Jul 21, 2013 | 03:03 PM
  #9388
TORETTO's Avatar
5k can get you a used SC and tune. but nothing else.
Old Jul 21, 2013 | 03:05 PM
  #9389
3rdG's Avatar
Car is parked and alarm is set. Left rear tail light is on. It actually doesn't matter if the alarm is set or not it stays on. Didn't notice it last night.
Does my 05 coupe have a European style parking light? I checked the blinkers and all lights, nothing is turned on.
Old Jul 21, 2013 | 03:06 PM
  #9390
Wi-Z_Sam's Avatar
I Know it has been done without it, but just mypersonal preference to upgrade the engine and get everything new unless you really know who you are buying from ~ reliability
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
