Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Dec 26, 2013 | 10:11 PM
  #9826
itgogitrev's Avatar
Stereo question: Will a 2005 Bose unit work with a 2004 finisher plate?
Old Dec 27, 2013 | 08:55 PM
  #9827
silver9's Avatar
19x8.5 +35 wrapped in 255/40 Pirellis. I had a 25mm spacer on and decided to give it a try knowing it would rub even though my fenders are rolled. It did and I removed them to save my tires. Question If I ran a tad bit of negative camber, would it work? Because honestly, it looked absolutely incredible. It wasn't sticking out or anything stupid like that; it was perhaps the flushest of all flushity flushness. Please advise.
Old Dec 27, 2013 | 08:57 PM
  #9828
herrschaft's Avatar
I would start by going with a 35 profile on the tire.
Old Dec 27, 2013 | 10:26 PM
  #9829
TORETTO's Avatar
^ That.
Alternatively, you can just put a 20mm spacer instead of a 25 and see if it clears.
Old Dec 27, 2013 | 11:15 PM
  #9830
silver9's Avatar
Thank you gentlemen. I won't be changing the tire since these are $1100 Pirellis. Here are pics of how it looked.
Old Dec 27, 2013 | 11:31 PM
  #9831
TORETTO's Avatar
Looks nice and beefy. But it does look like it will cut up your fender + tire. Add some camber or shove a 20mm.
Old Dec 28, 2013 | 01:47 AM
  #9832
Frankieg35's Avatar
I'd go smaller spacer to save tires from uneven wear..
Old Dec 28, 2013 | 08:14 AM
  #9833
NFSP G35's Avatar
? = 2B || !2B
You should reeeeeally try to research how your tire responds to neg camber. I had Hankook tires that the inside wore like crazy, but the Nitto NeoGens I have now, have been golden, and my camber is actually worse now.
Old Dec 29, 2013 | 04:23 AM
  #9834
cto917's Avatar
Lol if you did your research then you failed to mention that neogens were designed specifically for negative cambered vehicles to have even wear on tires...
Old Dec 29, 2013 | 05:50 AM
  #9835
Blue Dream's Avatar
I drove ttrank's car solo
simple answer is no.
Old Dec 29, 2013 | 08:56 AM
  #9836
NFSP G35's Avatar
? = 2B || !2B
I knew when I bought the Hankook tires that Nitto advertised the NeoGens as built for neg camber, but I wasn't sure how much of that was real, and how much was just trying to sell tires. The Hankooks were highly recommend... Turned out that was more hype, and now that I'm on Nittos, they actually are as good as they claim.
Before a purchase, it's hard to sort hype and propaganda from real facts. After actually owning different tires on the same vehicle, it's a lot easier
Old Dec 29, 2013 | 10:29 AM
  #9837
nism0b0y's Avatar
Ok so random light help... I bought a fancy pants set of led interior lights. And they worked great for a while and were super bright but as of late they have been working some of the time and not turn on at all no matter what! It's super annoying.
So the question is would I be able to get them working again with a light sanding to help them get a better contact? Or should I just go back to the original style bulbs and trash these??
Old Dec 29, 2013 | 10:58 AM
  #9838
TORETTO's Avatar
LEDs are pretty cheap right?
Just replace them.
Old Dec 29, 2013 | 01:27 PM
  #9839
dofu's Avatar
20 Year Member
The LEDs themselves can last a very long time, but the supporting parts on that bulb replacement may burn out. Where did you order them from, and why would you think there is something wrong with the contact points? IMHO, just order new ones. I would look for a different store. I usually get all of my LEDs from vleds.com
Old Dec 29, 2013 | 03:41 PM
  #9840
cobycoconut's Avatar
HELP! 05 sedan
I want to change all lights on dash white! I know you can on the cluster. But what about all the way down the center dash!? I'm just really tired of the orange color. I just want to know if this is possible and how much it would cost??
Attached Thumbnails Random Little Question Thread-forumrunner_20131229_144152.jpg
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
