Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jan 7, 2014 | 08:18 AM
  #9886
TORETTO's Avatar
it's for strutting
Old Jan 7, 2014 | 08:41 AM
  #9887
WhosUrBuddiee's Avatar
Originally Posted by rnguyen
What is the purpose of a strut bar?
Provide additional rigidity between strut towers. In theory, they reduce body flex during hard turns. In reality, they are a pretty show piece made to bling up your engine bay.
Old Jan 7, 2014 | 02:34 PM
  #9888
totopo's Avatar
Originally Posted by Ramanl
Can someone help me understand different brakes
I have 03 non brembo brakes, and im just wondering what slotted and drilled brakes are all about?
I see a lot of g's with bigger rotors and calipers, do most people do that for performance or looks?
Most people do it for looks. Good brake compound and fluid goes a long way. Unless you go to a road course and track your car, you don't need bigger brakes. bigger, slotted, crossdrilled rotors don't really affect your braking in daily driving. Your panic stop distance is almost the same.
Old Jan 7, 2014 | 02:37 PM
  #9889
totopo's Avatar
In addition, when the engine bay gets hot, the strut bars will expand, thus giving your car more positive camber, which is a bad thing. It does improve chassis rigidity though.
Old Jan 7, 2014 | 04:07 PM
  #9890
rnguyen's Avatar
So basically it has more negative effects than positive effects?
Old Jan 7, 2014 | 08:43 PM
  #9891
totopo's Avatar
Hard to say, up to ever individual to see if the benefits outweigh the negatives. I threw them on because theoretically they may prevent long term flexing and misalignment of the chassis, but I definitely wouldn't expect them to improve handling in the short run.
Old Jan 7, 2014 | 11:00 PM
  #9892
rnguyen's Avatar
Oh okay. Thanks for all the info!
Old Jan 7, 2014 | 11:23 PM
  #9893
They basically have no effect for a daily driven car except aesthetic appearance.
Old Jan 8, 2014 | 03:59 PM
  #9894
dominate's Avatar
When a 5AT G is put into drive, is the rear drop down noticeable? If so how much? I'm getting coils installed soon and if the rear drop down is noticeable, I would want to set my coils so that when parked, the rear is almost unnoticeably higher, and when in drive, I have a level stance. Thanks
Old Jan 8, 2014 | 04:20 PM
  #9895
Huh?
Old Jan 8, 2014 | 04:22 PM
  #9896
dominate's Avatar
I've heard that when a 5AT is shifted into drive, the rear end of the car lowers
Old Jan 8, 2014 | 04:24 PM
  #9897
Someone was screwing with you.
Old Jan 8, 2014 | 04:41 PM
  #9898
dominate's Avatar
Thanks
Old Jan 8, 2014 | 05:52 PM
  #9899
totopo's Avatar
This is correct. It is called squat (or anti-squat when it goes the other way)
here is one description
http://www.how-to-build-hotrods.com/tuning-4-link.html
In the stock g35, I believe the movement is minimal if there is any at all. But if you lower the car, you move the roll center, and it can become significant enough to be a problem.
The thing is, if you see when you are parked in drive, it is even worse when you are accelerating with normal driving. To fix this properly, you need roll center adjusters. Or really really stiff springs.
Old Jan 8, 2014 | 06:11 PM
  #9900
dominate's Avatar
Thanks,
So if I had my rear coilovers set so that the wheel gap was .25" (just throwing a random number out there) more than the front, it would not make a difference when the car is put into drive?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
