Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Mar 31, 2014 | 12:42 AM
  #10036
rnguyen's Avatar
Hey guys I recently just noticed that my steering wheel shakes a lot when I'm driving around 65-80 mph. At lower speeds it is completely fine. It never shook before when I was driving in higher speeds and now it has. Anyone know the problem??
Also I drive from denver to grand junction a lot and there are a lot of steep hills. When I brake my cars starts to shake also. I recently replaced my brakes and that stopped the shaking for a couple months and now it's starting again! Help my car please!
Old Mar 31, 2014 | 07:14 AM
  #10037
g35loving's Avatar
Did you replace the rotors also? Have you checked your wheel bearing?
Old Mar 31, 2014 | 07:47 AM
  #10038
NFSP G35's Avatar
? = 2B || !2B
I assume you ruled out tires as a cause?
Old Mar 31, 2014 | 01:00 PM
  #10039
rnguyen's Avatar
Tires are in good condition. I'll take it to a shop since my iq on brakes, rotors and stuff are very low haha
Old Mar 31, 2014 | 04:49 PM
  #10040
rnguyen's Avatar
Do you guys know what kind of rotors are good that aren't that high of price??
Old Mar 31, 2014 | 04:58 PM
  #10041
Diode Dynamics's Avatar
R1 Concepts makes a pretty good rotor and sells them for a fair price
Nick C.
Old Mar 31, 2014 | 09:09 PM
  #10042
rnguyen's Avatar
I'll check them out. Thanks!
Old Mar 31, 2014 | 11:22 PM
  #10043
mags's Avatar
coupe ft bumper on sedan
Will the coupe front bumper install properly on the sedan?
Old Apr 1, 2014 | 02:16 AM
  #10044
Hotdawwgman's Avatar
Nope... Not without changing the hood, headlights and modifying the fenders....
Old Apr 1, 2014 | 04:17 AM
  #10045
cto917's Avatar
Have you ruled out alignment as a cause? Or even wheel balance?
Good cheap rotors at brake performance.com. I think that's the website. American made and I use em for w.e. Not tracking of course but its fine for everything else.
Old Apr 1, 2014 | 04:18 AM
  #10046
cto917's Avatar
Sorry forgot to elaborate. Steering wheel shake should be alignment and wheel balance related. Braking can still be those mentioned above as well as rotors.
Old Apr 1, 2014 | 02:13 PM
  #10047
rnguyen's Avatar
I'm pretty sure that my rotors are warped because my steering wheel and whole car shakes... If I replace my rotors do I have to get new brake pads as well?
Old Apr 1, 2014 | 02:27 PM
  #10048
I suggest taking it to an O'reilly first and seeing if they can resurface them on a lathe. It's worth a shot IMO
Nick C.
Old Apr 2, 2014 | 01:29 AM
  #10049
G_DiRTY5's Avatar
[QUOTE=jeggo;6887241]Anyone know what part is this? Pretty sure it's a resistor for something. It started vibrating earlier. It's not doing it now but I'm just wondering what it is and why it vibrated so bad. I could hear it from inside the car.
That little black 'box' is the ballast for your HID headlights.
I need an opinion on these coilovers here
http://www.neo-motorsport.com/makes/...id=213&type=gt
A place near me is selling them for $750 without dampening and $1000 with dampening.
Any thoughts?
Thanks in advance!!
Old Apr 2, 2014 | 07:25 PM
  #10050
MrTBahgs's Avatar
Bump - still hoping for any help, ideally with the part name or something more i can research for this.
Originally Posted by MrTBahgs
Unsure what the piece is even called that I am trying to look for so its been hard to search for much.
I have an '06X without nav so my antenna is the little circle button on the roof near the front windshield, no shark fin or anything, just a black circle. The black plastic on the top half cracked at some point and half of it is now off exposing the metal magnet/antenna beneath it. I'm not sure if that's a bad thing or not when it comes to water hitting it, but either way it looks bad seeing the metal and like a green ring or whatever else the antenna has where its normally covered up.
What would be the name of the part there so I can look for a replacement and has anyone changed theirs before? That magnet is crazy strong so Im not sure how much work it would be to take the whole thing off so that I could replace both halves of the plastic or if I'd be better just fixing the upper half. Or a third option if its all one unit, I can get the entire plastic covered magnet/antenna and just plug my cord into the new unit.
I assume it would be a simple job as long as I had the parts and wouldn't need to bother with a dealer fixing it, but if someone has experience dealing with theirs, Id appreciate the insight.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
