Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Jun 18, 2015 | 04:07 PM
  #10321
blitzace137's Avatar
Originally Posted by saywat?
id buy it from ebay. the design is simple enough that they can really screw it up imo. i think those lips are so ugly but very popular idkw.
Really I think they don't look to bad. Not to many options with the sport bumper. It's either this the ING or chargespeed. Unless you guys know of other options.
Old Jun 18, 2015 | 04:09 PM
  #10322
saywat?'s Avatar
vertex makes the best lip for the sports. but its pricey. theres a guy here selling his used one but it aint cheap but looks fkn sexy as fk. also i saw a utr style one for the sports on ebay. that would be good too better than the data design
http://www.ebay.com/itm/06-07-FIT-FO...8df149&vxp=mtr
Old Jun 18, 2015 | 08:12 PM
  #10323
CG4DR's Avatar
Check the ads on this website.. R1 Autoworks Inc. makes exterior parts for the coupe
Old Jun 19, 2015 | 10:09 AM
  #10324
Peoria35sedan's Avatar
What he said + maybe ask your coupe questions in the coupe section
Old Jun 30, 2015 | 12:16 AM
  #10325
aminunti's Avatar
Air intakeee
hello everyone
to be honest im new to this car and infiniti g35 which i bought it 3 months ago
recently i ordered a JWT air intake but they just sent me the filter (it was my mistake that i didnt get the whole package it would be cheaper i know) , now im stuck with this filter and dont know what to order to put it in the filter and make it fit , the fliter it self is to big to go in the g35 tube
i saw some stuff online that might work but i dont really know , VELOCITY STACK!!!
Old Jun 30, 2015 | 11:01 AM
  #10326
drifterxG's Avatar
Originally Posted by aminunti
hello everyone
It's supposed to mount straight onto your MAF housing...unless you're missing that metal bracket that goes in the cone. See pic for reference:
Old Jun 30, 2015 | 12:52 PM
  #10327
aminunti's Avatar
YES im missing that metal part and i cant find it online even on ebay
and had a another question
they sent me a filter that doesnt look as efficient as others i think its pretty old do you think i should return the item ?
the chrome cap is solid cant get it off !!
Old Jul 1, 2015 | 12:05 PM
  #10328
drifterxG's Avatar
I'd return, and just buy the whole kit. Or you can buy my Fujita air intake. It's a clean polished one piece with washable filter.
I can send you more pics.
Old Jul 1, 2015 | 08:17 PM
  #10329
aminunti's Avatar
thanks for the help im gonna return it and order a new one and thanks for the offer
Old Jul 4, 2015 | 10:59 PM
  #10330
CG4DR's Avatar
I like my Takeda intake. It uses part of the stock airbox with a cone (washable) filter.
Old Jul 18, 2015 | 03:15 PM
  #10331
GreenPenguin's Avatar
2005 6MT Sedan 126k
Had a leak in the top tank of my stock radiator so I ordered a Koyo V2588 and just finished the install about two hours ago. Had one small issue with a cracked tab on the fan shroud but I was able to repair it. Anyway, I added coolant to the system and idled the car with an eye on the temp gauge and then took it for a spirited drive. The needle on the temp gauge never went above half once which I found odd because its almost a guarantee that air is introduced . I checked and confirmed the heater is blowing hot so maybe there is no air in the system?
I had heard that the G is notoriously hard to purge of air so it had me thinking maybe the temp gauge is incorrect. I do currently have the non functioning fuel gauge issue so I ran the instrument cluster test and everything besides the fuel gauge appeared as it should have in the diagram.
Its scary to think the engine could be overheating and I wouldnt even know it. Any suggestions?
Old Jul 18, 2015 | 06:11 PM
  #10332
NFSP G35's Avatar
? = 2B || !2B
The temperature gauge on our cars (actually almost all modern Nissans) is basically useless.
It's extremely 'center weighted' by the computer.
It hits the middle at around 150 and stays in exactly the same position until well over 220
Old Aug 6, 2015 | 02:25 AM
  #10333
dominate's Avatar
My sidemarker lights, parking lights, tail lights, and license plate lights won't turn on. This happened right after I replaced my parking lights with LEDs. (I may have had the light switch on when putting the LED in) Does it sound like a fuse problem? Do I check the fuse box behind the battery?
Old Aug 6, 2015 | 09:26 AM
  #10334
Diode Dynamics's Avatar
Have you checked the LEDs to make sure you have the polarity correct? Take them out, rotate 180 degrees, if they still don't come on, you may have blown a fuse during the installation or have bad LEDs
It's highly unlikely that all of your LEDs failed though
Nick C.
Old Aug 30, 2015 | 06:23 PM
  #10335
MrTBahgs's Avatar
2006 G35X, SES light came on today and since I have an Uprev cable I pulled the code.
P0462 - Fuel level sensor circuit low input: http://infinitihelp.com/diy/obd_code...initi_g35.html
I will first monitor it and clear it myself if it doesn't go away after a day of driving, but just figured I'd see if anyone else had experience with this.
I have read our fuel gauges aren't accurate, Im not sure if this is the exact same general experience, or this is more related to the code, but my gauge will at times go to say 1/4 or 1/8th of a tank and then later slide up to like 1/2 a tank, and then possibly shoot down and turn on the gas light after a bit.
I just go by mileage and when at 300ish i fill up the tank, usually get 18.5 mpg so that puts in like 17 gallons, perhaps I let it run too low and should get in the habit of filling it up sooner? Not sure if that would help/change the situation at all.
If this does require the fix listed in the link (I am kind of surprised its under the rear seat) then is it something I would HAVE to do, or can I just ignore it and not rely on the gauge? I'd think this is a $200 fix or more and unless it can cause other issues, a faulty gauge isn't worth that to me, especially when it would likely just go to the normal not very accurate gauge lol.
Either way, if you have some input on the code, I'd appreciate it.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
