Random Little Question Thread
Originally Posted by 03IP
Damn, dude. I read this last night and thought I'd check this out today.
When I was gassing up today I opened the gas door and locked my car doors with the fob thinking that the lock pin would pop out and I could take a pic. Now mine doesn't lock at all.
Maybe this is coincidental and it just bit the dust. I kneeled down beside it while locking the doors a few times after and it doesn't sound like it's even firing. I've got some troubleshooting to do.
This was my solution. It actually works as originally intended haha. My actuator works just fine.
Sorry!
Attachment 195699
Attachment 195699
Nice screw mod.
Received 2,469 Likes
on
Coupe 6MT Premium RAS
Technically there's no load on the rings and they're basically just for aligning the wheel when mounting so.... either would work. If you plan on tracking the vehicle or are notorious for being VERY hard on the brakes then I wouldn't even consider plastic due to the heat they would experience (might melt). Personally I would go aluminum because it seems a little chinsy to use plastic ones, actually let me rephrase that, personally I have hubcentric spacers so I don't need to use rings so...
I drove ttrank's car solo
Received 1,486 Likes
on
on
What exact year/chassis/package is your vehicle (ex. '06 coupe premium) it's also possible to clean the switch which usually helps. Remove the switch from the seat, unplug the harness, then on a work bench open the plastic housing for the switch (just depress a few plastic tabs with a flat blade screwdriver). Get on a pair of nitrile gloves in a well ventilated area and spray it down with electrical contact cleaner. Once it has evaporated use silicone grease to LIGHTLY lubricate the plastic hinge points of the switch (use a toothpick to keep it only on the hinges) and reassemble.
