Random Little Question Thread
Received 2,469 Likes
on
Coupe 6MT Premium RAS
? v35 v36? im drinking i think ur trollin me hahahah
If i could get a straight answer id appreciate it i have a bit of money riding on a deal but i dont want buy them if they dont fit lol
ive been searching since i posted this
on
V36 platform is the 2008+ coupe and 2007+ sedan.
The confusion happened because this sub-forum is for the V35 sedan which ended in 2006. Since you're asking coupe questions, yes the 2007 projectors will fit in the earlier coupes, plug-n-play just swap over your existing ballasts if they didn't come with any. You will need the newer style lamps for the newer projector headlights, all the lamp, primary, turn signal, parking, etc.
power loss??
so i just bought 06 g35 sedan and i can only get 8.5 ish 0-60 i dont have good tires and not the best at shifting yet but i dont know if that should cost my a whole 2.5 seconds, this might sound dumb but if someone knows how many seconds it takes to go 50km/h(30mp/h) to 100km/h(60mp/h) in second gear only, and if you could let me know so i could compare my time i feel like that would let me know if i might have power loss, if u have coupe thats fine too ill just expect a little slower time. thanks
thinking about it you might be onto something with damaged exhaust because car is pretty low and could have gotten banged up from previous owner, i will have a look tomorrow thanks for the help. but i do also think i am spinning way too much in first for a good 0-60 and i spin a little in second i think i have poor tires. and no codes
Hi all I have a 04 G35x and today I’ve noticed the air bag light constantly blinking. There is an option to reset it by turning the key to on and off 4 x’s but it doesn’t work. I’ve tried it every couple hrs. Went into my homies shop but he was swamped with work. And he says usually it takes a couple hrs to diagnose. Anyone have a clue what could be causing it to blink? For 2 the car had a dead battery for approximately several months and I just let her sit. Any help would be greatly appreciated!
on
You can put the SRS system into diagnostic mode and it will flash a code telling you what the problem is.
Yes there is a reset/pedal dance to reset the system, check section SRS - Supplemental Restraint in the FSM.
https://www.nicoclub.com/infiniti-service-manuals
Spec D
i have spec d headlights and the caps that come with it fell off so my ballasts are exposed, my standard lights still turn on but my headlights(high beams i guess) dont work, ive replaced the ballast before, and whenever it rains they stop working. If i get caps to cover the ballast will that prevent them from turning off or do i have to protect the wiring too?
