Random Little Question Thread
Don't know of any manual. But look for any screws. A lot of cars have little trap door looking things hiding screws underneath. Just pop it off with a flat, and unscrew it. It's most likely held on with screws and clips/tabs.
Example:
EDIT:
Looks easy enough.
http://www.ehow.com/how_5453293_remo...nfiniti-g.html
Example:
EDIT:
Looks easy enough.
If you can't get the interior panels off I would not try to do your own paintless dent removal. That is an art itself and those guys have a bunch of different tools. Its very easy to make a nasty high spot and stretch out the metal.
^That is a valid point.
But in the interest of proving the RLQT's usefulness... here is the info you seek, oh cloven footed one: http://psedog.com/cars/fsm/g35/
Example:
EDIT:
Looks easy enough.
Example:
EDIT:
Looks easy enough.
^There's a pedal below the steering wheel.
Driver's side footwell, all the way to the right.
That's where your fuel consumption problem is coming from, if you make sure nothing touches that pedal, your gas light will not come on for quite a while.
Yeah I guess that's my problem to much gas pedal. I'm gonna look into that some more
